Hi,
When the Mini playfield is down (level 1), when the ball hits the central target and activates the 2 locks, then the switches 71 and 75 (normally used for levels 2 and switched on each time the left and right grey button are hit) are triggered 3 times each without action.
The 2 corresponding columns of red lamps at the left and at the right of the matrix are lit - see attachment -.
The counter of hits which is initially 15 for the level 2 is decreased by 6.
Also when the ball hits metallic parts of the MPF - level 1, the same happens for one contact at a time. It can then happen that level 2 is reached with a counter at 0 and the MPF goes immediately to level 3.
I think of bad contacts with the level 2 optos, but I do not know what to look at. The voltage is good at the 5 receiving optos and varies as expected when the grey button is pushed.
If someone has an idea about the problem, you are welcome to share it
