(Topic ID: 286955)
Doctor Who occasionally launching 2 balls into shooter lane
By drsfmd
  • 46 posts
  • 12 Pinsiders participating
  • Latest reply 43 days ago by gcp
#1 3 years ago
I have an intermittent, but persistent problem in my Doctor Who that has me scratching my head...
Once every few games, 2 balls will be launched into the shooter lane. It never happens at the start of a new ball. It usually happens after locking the first ball into the Tardis, but sometimes upon ball save as well.
I have replaced the switches in the ball trough, in the shooter lane, and the launch button, to no avail. The switches (even the old ones that were replaced) test perfectly in the switch test, 100% of the time.
Any ideas for things to look at? I’m stumped!
#2 3 years ago
At first I’d say check diode on shooter lane switch but sounds like you changed all that.
Check for magnetized balls or trough with divots not allowing balls to feed properly
#3 3 years ago
Quoted from PNBLWZD:
New diode when the switch was installed. Balls were changed recently and are not magnetized. The trough has a cliffy installed, but the problem existed before (and after) the installation of the cliffy.
#4 3 years ago
Bump. Anybody have other ideas?
#5 3 years ago
Does it kick the first ball out before the 2nd is put in the launcher or does it stack them?
#6 3 years ago
I have never owned a Dr. Who. I worked on a 1993 Indiana Jones and I eneded up having to pull out the two opto boards in the ball return lane and replace several Of the diodes that both sent and received.
The divisors in the trough are also symptomatic of this.
Only other time I saw something like this was when a game had too many balls in it.
#7 3 years ago
Quoted from alexanr1:
I have never owned a Dr. Who. I worked on a 1993 Indiana Jones and I eneded up having to pull out the two opto boards in the ball return lane and replace several Of the diodes that both sent and received as part of the trough design.
The divots in the trough are also symptomatic of this.
#8 3 years ago
There are no divots or optos on this era of trough so it's not any of that stuff.
It's almost surely the trough switches themselves, or possibly the lock switches in the moving playfield (does the game think you have a lock?).
It's also possible it's a "mechanical" issue, in that maybe there's something in the wood / trough area that's causing the balls to sit funny on the switches. A good way to figure out if it's this kind of problem...does it only happen when two balls are in the trough? Like, you just locked a ball and now two get kicked out? If so it's probably this.
Perhaps take off the apron and carefully watch how it's operating when balls move around in there.
Beyond that I'd carefully check the MPU board for acid damage.
#9 3 years ago
Quoted from CrazyLevi:
It's almost surely the trough switches themselves, or possibly the lock switches in the moving playfield (does the game think you have a lock?). It's also possible it's a "mechanical" issue, in that maybe there's something in the wood / trough area that's causing the balls to sit funny. Perhaps take off the apron and carefully watch how it's operating when balls move around in there.
I would double down on these sentiments. My feeling is that it's a switch.
#10 3 years ago
Quoted from bbaker2824:
One gets kicked out, auto launches, and the second ball is kicked into the shooter lane before the first ball has come to rest on the VUK.
3 balls installed, which is correct.
Like I said the switches in the trough, shooter lane, and the launch button are all new-- replaced in an effort to resolve this problem.
I've spent a lot of time tinkering with those switches, but I'll pull the apron again, and tinker more.
MPU is good. No acid damage at all, NVRAM installed by Aardvark about 18 months ago.
#11 3 years ago
They are all on the same column in the switch matrix. I haven't had any problems with the coin door switch or the slam tilt switch, but I should probably take a closer look at J206-2.
#12 3 years ago
Quoted from drsfmd:
Break the opto beam(VUK) as soon as you launch the ball and see if another ball if released in the outlane. Eliminate any opto issues
are you sure you are seeing the trough switch closing in switch test? Have you buzzed it with a meter?
May have to repin the connector .
#13 3 years ago
Quoted from eyeamred2u:
The trough switches are mechanical, not optos. Yes, the trough switches open and close as appropriate during switch tests with a ball. I am not able to find any errors during repeated switch tests.
#14 3 years ago
For some reason, I can't edit the post... I'll check the VUK opto. I haven't tested that one yet.
#15 3 years ago
Quoted from drsfmd:
Yes, the troughs are mechanical and are very sensitive and if adjustments are made with PF up in the air, sometimes the game will react differently when PF is in lower position.
#16 3 years ago
You indicate it happens after you lock a ball.
So pay VERY close attention to what happens (with apron off) when you do this.
I can almost guarantee that with 2 balls in trough something weird is happening that isn't happening when you have three balls in there. Could be because of the position of the switches or wear in the wood path from the troughs to the shooter lane. I know you replaced switches etc but this is very sensitive stuff if something is just a little off this could happen. Could even have something to do with the positioning of the lever that kicks the ball into shooter lane.
#17 3 years ago
I took a close look with the apron off, and played about 10 games without the problem occurring. First game with the apron back on, it happened again.Arrrggghhh!!!
#18 3 years ago
Quoted from drsfmd:
Yeah that sucks but look at it this way - maybe it has something to do with the apron!
You can't discount ANYTHING when it comes to annoying shit like this.
#19 3 years ago
Hmmm... I’m not sure what it could possibly be on the apron, but I’ll tinker some more tonight.
#20 3 years ago
Oh, and for the record, the drain switch, the three trough switches, the two shooter lane switches and the telephone onto all checked out just fine.
#21 3 years ago
I know you checked it but it sure sounds like a problem with the trough switch for ball 1 or 2.
My theory.. it happens when a ball is locked. 2 balls in trough. 1 kicks out. The machine isn't seeing a ball missing so kicks out another. Perhaps the switch for ball 1 isn't registering if another ball isn't pushing it???
#22 3 years ago
It’s a good theory, but I tested the trough with a single ball, and it registered every time. I *could* move the Cliffy a bit and see if it helps any, but the problem existed before the Cliffy was installed.
#23 3 years ago
Quoted from drsfmd:
Take a pic of the apron, lets see how the metal rod is mounted, maybe the ball is making contact as it ejects into the outlane.
#24 3 years ago
I don’t understand- you want a photo of the apron installed, looking into the eject hole?
#25 3 years ago
Quoted from drsfmd:
The only thing that could be interfering with the ball is the metal rod attached to the apron. If it mounted too high/low, it may be impeding the ball. Otherwise, there is nothing on the apron that would cause your issue, that I can think of.
#26 3 years ago
Sounds like a mechanical issue not an electrical issue especially when it doesn’t happen with the apron off
#27 3 years ago
I think this is the photo you’re asking for...
DAC73675-C854-4A4B-8C43-EA2DB1E2A678 (resized).jpegDAC73675-C854-4A4B-8C43-EA2DB1E2A678 (resized).jpeg
#28 3 years ago
Play for an hour or so with the apron off, if everything works OK then play with apron on. If problem happens again then you know it has something physical to do with the apron and can focus on that.
#29 3 years ago
Quoted from drsfmd:
I think I know what is happening. When you put your apron back on, the ball is hitting the ball guide. See my pic. Bend that ball guide towards the coin door and see if that helps.
#30 3 years ago
I'll give that a try after work and report back.
But the apron isn't part of that equation, so I'm not sure why the problem goes away when the apron isn't in place.
#31 3 years ago
Bent the ball guide as suggested-- no change.
#32 3 years ago
I would take the apron off and keep messing around with it.
Quoted from no-extra-balls:
Yep this is what I'm thinking too.
#33 3 years ago
Quoted from drsfmd:
It looks like when you put the apron back on, the small bracket is interfering with that ball guide from my perspective and when u remove the apron, the problem stops.
Take a video: one with apron on and one without
#34 3 years ago
So Aphex and I tinkered around with it again tonight, and I think we *might* have figured it out. The ball guide that sits horizontally above the outhole had a gap that was significantly smaller than the other WPC games in my collection. We bent that, and played a handful of games without the double launch happening... so we may have stumbled into the solution.
#35 3 years ago
...and... it just did it to both of us in a two player game.
*sigh*
#36 3 years ago
This^^^^^
Or take the apron off and play until it happens again or until you're convinced the apron might have something to do with it.
1 year later
#37 1 year ago
I know this is an older post although I would like to know if this was resolved as I am seeing the same issue on a Dr Who machine.
#38 1 year ago
Quoted from martymart:
Nope. It doesn't happen often, but maybe once every 10 games it will randomly happen.
#39 1 year ago
Quoted from drsfmd:
Have you checked for broken/loose wire at J206-2 on the MPU?
Bad solder connections on the outhole switch itself or wrong gap.
Perhaps the outhole switch is just failing and is sticking closed for too long and releasing a 2nd ball bcuz it doesn't close fast enough. What have you tried to remedy the situation?
#40 1 year ago
Agree with Eye that it is probably a switch in the ball trough or in the shooter lane. Those wires that stick up through the PF can get stuck in the down (closed position or UP by being too close the wood they protrude through. The pivot point on those switch wires also crack with age/use. Because it is occasional, I would bet it is not a broken switch but a sticking switch.
Several things happen in sequence, and it is quite complicated. There are the 4 switches in the ball trough. The first one with the wide blade and hook on the end, detects that a ball has drained. The next 3 detect how many balls are in the trough at any moment in the game. The switch in the shooter lane tells the brain that a ball was launched. If that switch is stuck down, it will try to launch another ball.
#41 1 year ago
I swapped the outhole switches for new ones.
I don't remember if I checked J206-2 or not, but I will (the other poster zombied an almost 2 year old thread of mine). I'll report back.
1 year later
#42 50 days ago
Hah. I randomly read this thread the other night, and now my Doctor Who is doing the same thing! The thread must be cursed.
I haven't spent any time trying to figure it out yet (other than everything looks fine in switch tests, etc).
Other possible clues I'll add to the discussion that's already here: In my machine, I've noticed that the launch button might be a little 'sticky' - staying closed after launching the ball, intermittently. Additionally, the shooter solenoid seems to be behaving weirdly and leaves the plunger in the extended position. It seems to do it every time in the solenoid test, while it usually behaves properly in-game.
#43 50 days ago
Quoted from gcp:
Your shooter rod issue is either a spring, liner or both issue.
Launch button also might be a spring issue or someone spilled a drink in there. Launch buttons are cheap and easy to replace.
The random shoot 2 balls issue happens even on new games. Some say it is because of magnetized balls and some say it is a bad trough switch. I have new balls, and new switches. It still happens occasionally.
#44 50 days ago
Quoted from Tophervette:
The spring was my first thought, but it looks fine. Haven't inspected the coil sleeve yet but will take a look. With power off, the plunger moves freely and the spring pushes it back to the normal resting position effortlessly.
Yep, annoying when those microswitches fail. Easy to swap out though and see if it fixes anything.
Interesting. I hadn't heard of issues like that. And don't recall ever having a problem in my first several years of ownership. (I bought the DW probably ~12 years ago, but it's been essentially powered off for the last ~8). I've certainly seen weird, schizo behavior in games like STTNG when the ball trough optos get flaky - so I'll be scrutinizing the ball trough switches for sure. But so far they seem fine...
#45 44 days ago
I had the same probkem with my Terminator 2. Same trough system. The problem was not any switch but the mechanism that kick the ball in the shooter lane. Sometimes it was sticking up too high and was blocking the next ball to activate the first switch. Plus I had some wear in the ball trough so the balls were stopping in some divots. In the end the problem was mechanical and not electrical.
#46 43 days ago
Interesting - thanks for the reply! Mine hasn't misbehaved in a week now; when it starts happening again I'll take a closer look at the eject mechanism. I didn't have any reason to suspect any issues there.
3,500 (OBO)
Johnson City, TN
$ 329.99
$ 9.99
$ 27.95
$ 9.95
$ 69.50
YouBentMyWookie
$ 14.95
3,700 (Firm)
Ronkonkoma, NY
$ 109.99
Bartlett, IL
$ 40.00
£ 110.00
$ 29.50
Playfield - Plastics
4,800
Mt Zion, IL
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/doctor-who-occasionally-launching-2-balls-into-shooter-lane and we tried optimising it for printing. Some page elements may have been deliberately hidden.
