Hey guys,
I've been having this issue with my DW for a while but am now just getting around to working on it.
Every switch of Column 4 grounds out in TEST mode and I've traced it back to my MPU. I swapped out a known working MPU and the issue goes away. I've tested from J206 pin 4 to C14 & R70. Both C14 & R70 test differently from all the other capacitors & resistors in their rows on my DMM in diode test. So I assume that's part of the issue... I was hoping someone has some insight on this type of issue...what might cause it and if I should worry about U20 as well.
ERIC
