All right, new thread; the old one was resolved.
The Doctor Who Mini Playfield is not going up and down. The motor works. Tested it with a 9 volt battery. Replaced the fuse, just in case.
Errors No CW Movement and No CCW Movement are the only errors I'm receiving.
While attempting a playthrough, this is what happens when the ball goes into the Time Expander: instead of locking, it kicks it back out (and progresses the Time Expander Dialog).
People familiar with the Time Expander know that it goes like this:
1) 7th Doctor locks (Ace, you have to do it too)
2) Ace locks
Countdown to opening Time Expander
The balls NEVER actually lock the first playthrough, which is unusual because in the past when the Time Expander was not operating properly, it would still lock the ball and launch ball #2 and then #3. Now it just waits until the countdown to launch all the remaining balls onto the playfield from the reserve gutter.
After losing multi-ball, the balls WILL lock (but the unit will still not go up and down).
What should I check next?
