At the end of the "Dr Who Mini Playfield Electrical Issue" thread, I mentioned that the MPF was working near perfect, but seemed low on the left at the Down position, and also was too low after descending to Mid Level. I thought I better move that issue to a thread with an appropriate title.
I pulled the MPF and performed procedure to correct canting. I wasn't able to correct the problem, though the MPF in the down position seems to be a bit more toward flush on the left side by maybe 1mm. If I grab the left side and pull up I can make the position almost perfect, but it doesn't stay in that position of course.
The following photos are of PF view and associated Home Opto (and cam roller) view at each position of the MPF in Test 14. CW and CCW are clockwise and counterclockwise respectively and refer to rotation of the MPF motor spindle as viewed from the front. L and R refer to the position of the cam roller being on the Left or the Right when the MPF is at Middle ("Mid") Level.
When moving CW, the motor stops when the opto becomes Unblocked. When moving CCW, the motor stops when the opto becomes Blocked. It looks to me that the motor turned a slight amount more beyond the point when the opto was completely blocked or unblocked, but I'd like to hear what others think. I checked the tightness of the motor spindle in the cam and the cam doesn't rotate round the spindle when I try to turn it and the set screws holding the cam to the spindle are tight.
1. CCW MidR (Ascend to middle level)
CCW MidR (Ascend)
CCW MidR (Ascend) Home Opto
2. CCW Up
CCW Up
CCW Up Home Opto
3. CCW MidL (Descend to middle level)
CCW MidL (Descend)
CCW (Descend) Home Opto
4. CW Up
CW Up
CW Up Home Opto
5. CW MidR (Descend to middle level)
CW MidR (Descend)
CW MidR (Descend) Home Opto
6. CW Down
CW Down
CW Down Home Opto Opto
7. CW MidL (Ascend to middle level)
CW MidL (Ascend)
CW MidL (Ascend) Home Opto
