(Topic ID: 219162)
Doctor Who mini-playfield gearbox/motor
By chaos19
2 years ago
  • 27 posts
  • 10 Pinsiders participating
  • Latest reply 2 years ago by pinball_faz
#1 2 years ago
My dr who mini play doesn't move in play or test mode. I get voltage on the motor on all the ccw and cw tests so I believe its the motor or gearbox or both. I can move the miniplayfield up and down by hand with some strength, does this mean the gearbox is stuffed. If it isn't I'ld like to buy a new 20V DC motor online but I have no idea of the RPM, torque or current. I emailed twice MultiProducts that built the gearboxes for Bally/Williams and they will not send me a reply (probably because I'am not a business). Also how do I unscrew the motor from the gearbox, its not as simple as my Indiana jones. Any info will be much appreciated.
#3 2 years ago
I would start with the bi directional board. There is a capacitor on there that likes to leak, and take out the trace below it.
#4 2 years ago
I started with the bi directional board and checked with my DMM and get +20v to -20v from the motor jumper with all cw & ccw tests as with the pins on the motor itself.
#5 2 years ago
I'm unclear if your motor is working at all. It sounds like you pulled the MPF... pull out the motor/gearbox then pull the motor off the assembly.
Plug the motor in the connector to check the motor. I really doubt the motor is burned out; it really does not get that kind of abuse.
faz
#6 2 years ago
Its the gearbox i'm most worried about, they cost over $200 here in Aus. I read somewhere that if I can move the cam wheel, which happens when I move the mpf up of down by hand (I haven't taken the mpf out yet), then my gearbox is stuffed. I would like a second opinion.
#7 2 years ago
Assuming "stuffed"=="not awesome"... and yea, probably is.
I'd be happy to do a Facetime/Tango chat if you want to talk through it?
faz
EDIT: Isn't it 3:00am in AUS?
3 months later
#8 2 years ago
I wish to bump this and say that if you hear some gear noises but the axle doesn't turn means your gear box most definitely is "stuffed." I had mine go out, and it's pretty obvious. It goes up and then just doesn't, yet the motor is spinning and (some) of the gears are turning, yet the axle on the opposite side isn't spinning... it's doomed.
#9 2 years ago
Pinball Resource may have one or rebuild for you.
#10 2 years ago
To test the motor.. remove it from the machine and attach the leads to a battery. Ive seen a 9 volt battery used most often.
#11 2 years ago
Quoted from yellowghost:
I've done that too, but it doesnt always indicate an issue. You're gear box can be going out and yet will still pass this test.
#12 2 years ago
Quoted from jorant:
Keep in mind that the game powers that motor with 11V more than the 9 volt battery, so if there is a problem with the gears, it should be exposed by this. Many people seem to disassemble the gearbox to “fix” a problem that isn’t even there. In my case, the motor wasn’t being given enough power while in the game because I had lost one of the -2- wires which are feeding the motor
#13 2 years ago
Quoted from Rdoyle1978:
If you lost one of the two wires, you won't just get weak power, you get NO power.
#14 2 years ago
Quoted from jorant:
Not 1 wire to the motor, there is a flasher (I think it’s the doctor 5 flasher) that the mini play field power also runs through - in my case, there was a connector that had 1 hot wire from the harness and 1 hot wire from that flasher which joined in the connector. The connector (if I am remembering correctly) is a 2-pin molex which then connects to the motor
#15 2 years ago
There is only one set of wires feeding the motor power. The flasher can be totally disconnected and not harm the performance of the playfield.
#16 2 years ago
Quoted from jorant:
yup... it's a DC motor. This is the one time where in "sci-fi" terms... "Reversing The Polarity" actually does something. -12V or +12V causes the MPF to move CW or CCW.
faz
#17 2 years ago
Quoted from pinball_faz:
faz
I wonder if mine was wired incorrectly? That is pretty bizarre
#18 2 years ago
Whoops... sorry.. I misstated something. The voltage is +/- 20V. and I'm not illustrating which voltage drives CW/CCW.. I don't remember. The important thing is that it's just a simple DC motor.
faz
2 months later
#19 2 years ago
pinball_faz
I am in a similar quandary. Recently purchased a Doctor Who and the MPF has been rock solid for a month. Two days ago it froze in the up position. On inspection, it appeared that the positive power supply wire to the motor popped its connection.
Upon reconnection, it worked fine for about a game and then MPF started slipping.
I popped the playfield up - and was able to move the MPF along its track with very little effort.
Here is a video -
Before I go out and drop the $, I just was hoping for some independent confirmation that the gear box is hosed - and my best course of action is ordering a new motor/gearbox and replacing that.
Thanks for any guidance. This is my first machine and I am excited to learn with this community.
Thanks,
Morbius
#20 2 years ago
IMO... something indeed is "hosed". But before you put a new gearbox/motor in you need to check a few things.
I hear the motor spinning really fast and the gear box jerking along. That's a combination that does not happen.
If the gear box is good and you stop the motion, the gears will break under all circumstances. It's direct drive, there's nowhere for the energy to go.
If the gear box is broken, why does it keep moving?
Check the path of the MPF completely on all four sides. Make sure it's 100% free of any binding/rubbing.
Use my white paper to tear down the whole thing and build it back again. Just the physical parts (leave the top of the MPF alone).
When the brackets are out, you need to run them with the motor alone up/down to make sure the action is smooth. If they got hung up, they warp/twist. You may need to reshape slightly.
I'm wondering if the set screw on the cam is loose or slipping. This would be a simple fix if that's the case.
Another possibility is one of the gears inside the gearbox has sheered off it's mount. There's some delicate repairs to repair the gear collet but unless it's done correctly it could turn into a lot of wasted time/frustration. But if you love to try to fix things, this would be a good one
Let me know. Glad to call you too.
faz
#21 2 years ago
Inside the box there is a brass sprocket pressed on a steel axle wich can be welded,
it fixed my problems ...
#22 2 years ago
Thanks, pinball_faz
I am going to take the MPF out tomorrow morning and follow your diagnostic suggestions on Sunday morning. Thanks for the offer on the call! I may take you up on that.
3 weeks later
#23 2 years ago
pinball_faz
It took me some time but I finally had some time to separate the motor from the assembly - and the same behavior is going on without being attached to the Cam.
See video -
It feels like a few of the teeth are grabbing on the screw, but generally it just slides or binds up.
Am I better off just buying an new gearbox and motor assembly at this point or is it worth while to attempt a fix?
If worth a fix, any idea how I break into that gearbox?
#24 2 years ago
Normally the case is held together with four rivets.
Looks like there's some torx screws. Assume there's a nut on the other side. Get a torx bit and open it up. Peek around but I see a new gearbox in your future. My guess is someone's already been inside hence the non-standard fastener.
I'm betting someone got medievil on the inside with a pair of pliers and blowtorch.
Should just unscrew nice and easy. Take some pics... and don't forget to share
faz
3 weeks later
#25 2 years ago
pinball_faz
Well, I got the motor gearbox and reassembled and while it wasn’t binding, I noticed a bit of torque at the top and bottom of the cycle (as the cam reaches the top and bottom).
During that, I noticed that the ring and e-clip on one side were missing. Does anyone know the size, part number, and/or designation of these?
Thanks again!
Morbius
F02FC9BC-6AC8-47B7-99FD-B5272AC1ABD1 (resized).jpeg90AE1630-4BF4-4C99-8411-AAD83AF4FDC2 (resized).jpeg
#26 2 years ago
Quoted from Morbius:
pinball_faz
Thanks again!
Morbius
[quoted image][quoted image]
Just take the entire thing to a good local hardware store. They should have a variety of e clips
#27 2 years ago
Dude... you have one of the e-clips.... take THAT to the hardware store and say... "I need one of these".
easy peasy
faz
$ 279.95
Pin Stadium Pinball Mods
$ 28.00
$ 11.00
$ 34.95
PinSound
