New! Dark mode!
(Topic ID: 258094)
Doctor Who F111 blows on power-up
By RocketFromTombs
10 months ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 9 months ago by dsuperbee
#1 10 months ago
Hey there everyone,
I have a Doctor Who that has been sitting for a few years that I want to get back into playing condition. I powered it up tonight, and F111 is blowing immediately upon power up. I pulled the power supply board and replaced BR4, put it back in the game, and the same thing happens. Any ideas?
Thanks,
Brian
#2 10 months ago
Unplug connectors involving F111. See if you have a board issue or a problem out in the game.
Was BR4 bad ?
#3 10 months ago
Could have a bad flasher, socket, or a short to flasher wiring.
#4 10 months ago
Okay, with no connectors plugged in to the board except for J102 (power), it's still blowing. I hadn't checked the original bridge when I changed it, just assumed it was bad, but I just used my DMM and it appears to be okay. I guess I have a short somewhere on the power supply board? (I didn't see anything obvious...)
#5 10 months ago
Quoted from RocketFromTombs:
Yes.
Shorted components can be invisible.
New BR4 good ? Then using your meter as best you can, go over the 20 volt section.
How's this ? 7812 -12V regulator ?
#6 9 months ago
Alright, it took a while due to a busy holiday week, but I got it all fixed.
There was a trace from one of the AC inputs on BR4 that was shorted to ground (looked like a solder splash). Took a bit of searching to find it, but I got it. I replaced the 15,000 microfarad capacitors while I had the board out, they were original and a couple looked like they were starting to bulge. Put the board in the game, and it's alive! WOOHOO! I still have some issues with the mini playfield that I need to address (namely no motion CW or CCW) and a couple of opto switches that aren't registering, but aside from that, everything works, and I was actually able to play a game - it's been about 5 or 6 years since I got to do that!
Thanks so much for your help, I really appreciate it.
-Brian
#7 9 months ago
-Brian
On the bi directional board under the pf that controls the mini pf is a cap. I am willing to bet it puked its guts out and took out some traces and possibly the chip on the board.
$ 5.00
$ 19.99
PinballElectronics.com
£ 99.00
