I picked up a Doctor Who that was DOA. I checked replaced batteries and noticed there was a lose wire grounding out the middle battery (see photos) and causing it to get very hot. I removed the wire and replaced the batteries and game turns on and I can start a game, but no sound now, so I check the fuses on the audio board and they were both blown, so I pulled the audio board and there was a clearly a blown trace on the back of the board and a couple blown capacitors too. I fixed the blown trace and put new fuses in and both fuses still blow upon start up. Has anyone had any similar issue with this machine. It looks like I will need to pull the other boards and see if that hanging wire damaged something else or if that was just a strange coincidence, but the game works now except the sound board blowing fuses.
09E95525-0B26-4E3D-9125-1FFC14D6F883 (resized).jpeg426D5485-6E2E-42F4-B379-61728A70D212 (resized).jpeg6A50A7D1-2D09-46A4-A5FE-72BC71F3DB10 (resized).jpeg70AFC506-01DA-4535-864E-3D01D3F805AF (resized).jpeg8223D6BC-7F57-4E21-8880-963B639706C0 (resized).jpeg95A3C429-BF76-4ADE-886C-28740177DF0C (resized).jpegA8962811-1318-469D-8745-E25A92E9E771 (resized).jpeg
