Does anyone know of the pinhead that was doing the Doc.Ock light mod?
Thanks DCFAN I was just searching through old posts and found mention of you installing a doc oc mod on someone elses machine. Sorry if I sent sb80 to you by mistake.
Best of luck in your search sb80
Quoted from DCFAN:Actually Biglaw! He does great work.
Agreed he does great work indeed!
thanks guys. doc 85.00 swap 165.00 straight out. goblin 75.00 swap 130.00 straight out. sand man 60.00 swap out 120.00 straight out. now plug and play off of the spot light of each just swap out the z connector.
!cid_0222132201_sandman.jpg // Error: Image 77284 not found // !cid_0714120015.jpg !cid_0901121944.jpg !cid_1111121945.jpg
so do the mods light thru activation or on all the time the game is on ? ie. if spot lights are on the mod is on . does mod flash ?
i also include a connector with just 2 wire ends with doc only. this way you can tie into fusion malfuction insert. but it one or the other. spot light or insert. mine is hooked to the insert. i havent had any problems. but some say it has caused ghosting.this is how mine is. red mod wire piggy back on yellow and black on side of insert useing the diode in the light socket. so if insert is flashing doc is flashing. if insert is on doc is on.
Mamemaster told me about you! He just bought a set. I am sending pm now. I would like a set of all 3 too. These look great. Love the plug n play capability!
This page was printed from https://pinside.com/pinball/forum/topic/docock-mod and we tried optimising it for printing. Some page elements may have been deliberately hidden.
