I have a flight 2000 that I'm going to clean. What do you use to clean it and do you wax it when it's done?
Bob
Bob
I never have but if the finish is good on it I would think it would shine it up. If you have big chunks taken out on it I would think it would just build up and gum up in there.
Quoted from oldschoolbob:I have a flight 2000 that I'm going to clean. What do you use to clean it and do you wax it when it's done?
Bob
I had an old timer recommend Scrubbing Bubbles some time ago for cabinet cleaning. Works fantastic. I don't use it on the outside of decal'd or screen printed, but pained cabs absolutely. Removes a lot of crap easy. For protection and shine you could use a wax, but as Pauz21 said if the surface is rough it'll just gum up. A clear spray on wax might be a reasonable alternative. I've used carnauba on a couple of smooth cabs with great results, but it's probably overkill.
I have used carnuba wax for all my pins, and have not experienced any problems. It definitely helps restore on screen printed or painted cabinets.
Quoted from pinster68:I had an old timer recommend Scrubbing Bubbles some time ago for cabinet cleaning. Works fantastic. I don't use it on the outside of decal'd or screen printed, but pained cabs absolutely. Removes a lot of crap easy. For protection and shine you could use a wax, but as Pauz21 said if the surface is rough it'll just gum up. A clear spray on wax might be a reasonable alternative. I've used carnauba on a couple of smooth cabs with great results, but it's probably overkill.
pinster, any specific guidance on using the scrubbing bubbles? or just follow the directions on the can?
Quoted from ccotenj:pinster, any specific guidance on using the scrubbing bubbles? or just follow the directions on the can?
Spray, wait, wipe off. In cabinet bases where the surface could be rough (or to get it out of corners) I've used a shop vac then a finish wipe.
SB also works excellent on metal/plastic ramps. I put them in my wash basin, spray with SB, wait 3-4 minutes then rinse with warm water. It really cuts the scrubbing time down.
As always use with caution on any questionable artwork, etc.. You never know. Start small, experiment, then use your best judgement.
The SB advice came from a fellow Jerseyite and RGP old timer. Let's just call him Ron S. to keep anonymity. Other old timers will likely know who I'm referring to.
Regards,
Brian
I may have to try this on location machines. Do kids that are hovering around and on the machine fall off if you use enough wax? I feel like I need a kid repellent to keep them off the game when I am trying to play.
I used this product on Gottlieb em cabinets only so I don't know about newer cabinets.
I found out about this stuff on a few old rgp thread threads I searched. It's called Super Clean and I was told it's made by Castrol. You can get it in an automotive parts store - just ask. After trying Mean Green and a few other similar products this stuff took even more grime off and didn't harm the finish. Always try a new product on an inconspicuous spot 1st.
As far as waxing goes, I would think if your pins were in a building with poor hvac conditions such as higher humidity (which could cause light mold to form), reduced air flow, etc., then it would be more important.
I wear rubber medical gloves and spray it directly on the top of the area you're cleaning and let it run down - rub it around so everything is coated and after it sits for 20 - 30 seconds I wipe it off. It works great.
Quoted from hoov:I wear rubber medical gloves and spray it directly on the top of the area you're cleaning and let it run down - rub it around so everything is coated and after it sits for 20 - 30 seconds I wipe it off. It works great.
cool... thanks...
I waxed my Bride of Pinbot with a hand buffer and carnauba car wax. It put a nice shine on it, however I will let you know my buffer pad afterwards was purple so it does have a small risk of pulling off the paint on decals. I am not sure about older cabinets though.
Thanks everyone.
I think I might try the Scrubbing Bubbles and Carnauba wax. But I'll test it first on the back side. I'll let you know how it comes out.
Again - thank you.
Bob
I like them waxed, glass too because dust wipes away so much easier. damp cloth dry cloth to the glass instead of windex for a quite a while too when the glass has been waxed, same for cab sides.
Quoted from zizzlemeplease:I like them waxed, glass too because dust wipes away so much easier. damp cloth dry cloth to the glass instead of windex for a quite a while too when the glass has been waxed, same for cab sides.
you wax your pf glass?
This page was printed from https://pinside.com/pinball/forum/topic/do-you-wax-the-outside-of-your-cabinet and we tried optimising it for printing. Some page elements may have been deliberately hidden.
