Quoted from branlon8:bit old now the thread, but what do people do ? often it is possible to just replace the microswitch according to the catalog number in the game manual, but sometimes the exact microswitch is hard to get.
So the alternatives are:
- buy a similar microswitch and bend the metal wire or
- buy a microswitch and replace the actuator as above
If you replace only the actuator what is the common practice
- replace the entire metal bit connected to the black plastic housing ?
- replace only the wire - how is it connected ? - with solder ?
Replace the switch body, take the metal actuator off the old switch and put it on the new one. This is really only necessary if the old switch actuator is bent in a particular way specific to that game
The wires are going back down to the harness, I don’t see how or why you would replace the wire.
That said, the switches in the original post up top are VERY sensitive to having their actuators bent. If those are bent, the whole switch can sometimes need replacing. For example, I had to replace one of those switches on the LOTR sword ramp, after I spent a full week tinkering with it to get it bent back up and properly trigger when a ball rolled over it but not stop the ball from rolling. I finally gave up and bought a new switch
