(Topic ID: 230142)
Do you do your own welding?
By HighVoltage
1 year ago
  • 67 posts
  • 31 Pinsiders participating
  • Latest reply 1 year ago by MrBally
    There have been 19 images uploaded to this topic. (View topic image gallery).
    There are 67 posts in this topic. You are on page 2 of 2.
    -1
    #51 1 year ago
    Quoted from tacshose:
    Great analogy!
    Really? Thick with irony and hypocrisy from here.
    #52 1 year ago
    No it's spot on. You get what you pay for. and there aint no miracle MIGs for $88!
    Best of luck.
    #53 1 year ago
    Quoted from HighVoltage:
    You're against learning a new skill oneself, are you?
    Of course not.
    BUUUUUT.... I'd suggest joining a hackerspace to learn - that's what I did. Not only will everything already be set up but they'll have scrap you can practice on. And helmets, gas, 220v, a metal table, clamps, plastic spark shields and a bunch of other stuff you won't have to buy.
    MIG works but usually requires grinding. TIG is very elegant but much MUCH harder to master.
    #54 1 year ago
    Quoted from benheck:
    Of course not.
    Excellent answer, if it's available in his community. Sign up for a minimal monthly cost, and you likely get some rather expensive toys to play with along with some great mentoring. If you take a liking to welding, then take the plunge and buy your own equipment.
    #55 1 year ago
    I usually won't pay anybody to do anything I can do or learn to do myself unless it is financially unfeasible to buy or rent the necessary equipment to do so.
    I look at life as a never ending learning experience and have saved bundles of money fixing everything including major repairs on my house by doing so.
    #56 1 year ago
    Quoted from mbwalker:
    Yeah, this is a good idea that hadn't come to mind, and is way more welcome from someone I respect than coming in with smart-ass comments that really weren't fitting anyway. I only started mentioning TIG because I heard it was good for thin stainless and saw someone doing torchless welding with an inexpensive TIG machine. I quickly learned that's actually just stick welding on a TIG and MIG was the way to go after some more research and thanks to people that actually came to contribute something, rather than try to get a laugh, which is easy to do for someone that has a bandwagon of nuthuggers (hi Tac!) to back him up.
    #57 1 year ago
    Quoted from o-din:
    Right on! That's the way to go, try to be a DIY'er as much as possible myself too.
    #58 1 year ago
    It sure helped during the two years they were paying me to be unemployed.
    #59 1 year ago
    This is the welder I use: https://www.eastwood.com/mig-welder-110vac-135a-output.html
    Great for small jobs. I've fixed and fabricated many pinball brackets with this.
    If you don't work on lots of games or have other hobbies that require welding, I suggest taking your parts to a shop. The cost for the shop to fix your one part is minimal compared to the cost of all the tools needed.
    #60 1 year ago
    Tell you what Nic- If we end up making a deal on the pins we discussed I'll toss in my old 110v MIG unit, its been doing nothing but gather dust in the attic storage. It was a little cranky time to time but still working when I purchased the unit I have now and kept it as a backup.
    Gary
    #61 1 year ago
    Yeah, this is a good idea...
    Considering you're in Seattle, I bet you have some stellar places to chose from. I saw a 'This Old House' episode not long ago where one of the guys went to San Fran to visit a hackerspace to make chairs. Wow, seriously loaded up w/nice stuff. CNC wood cutter (think: playfield). Laser cutters, etc. Big stuff, not like some of the smaller ones that end up in home workshops or pole barns. I bet someone with enough time and determination could make their own pin.
    #62 1 year ago
    If you've never welded before, find an old Miller white-face MIG cheap on CL.
    Those things can weld sheet metal all the way to 1/2" plate with ease.
    But the best part about them is that there are no circuit boards or integrated circuits or other nonsense to burn up.
    Everything on them is an easy repair. Really the only electrical part that dies on them is the fan and the rectifiers - both easy for any pinball owner.
    200lbs of pure welding bliss.
    #63 1 year ago
    Quoted from vid1900:
    200lbs of pure welding bliss. [quoted image]
    Had a large one with a four cylinder gas engine at the place I used to work. Eventually, the safety "gurus" stopped allowing employees to weld and auctioned off everything. Now a vendor comes in, rope's off areas, covers up stuff and does the welding. That $20K welder was bought for $300.00 by an employee.
    2 months later
    #64 1 year ago
    Since the local maker space only does a welding orientation once per month, and they skipped December, I had to wait 'til this past week to take that class so I could use the MIG. Thanks to some tips from a friendly pinsider with a git'r-done attitude, I decided to do the fix with MIG and the general mild wire it had loaded.
    I'm pleased how it turned out: it feels really strong as I decided to weld a bit beyond the tab. The weld is facing the back of the playfield anyway and doesn't need to look perfect. Already installed it, and it's working well.
    #65 1 year ago
    Just did my first solder core weld the other day to fix up an exhaust leak. I’m super proud of myself.
    What u guys think?
    #66 1 year ago
    #67 1 year ago
    Quoted from DNO:
    $ 40.00
    Arcade Arts
    $ 39.99
    $ 139.00
    Sparky Pinball
    $ 219.99
    PinballBulbs
    € 6.50
    Buthamburg
    $ 5.00
    $ 1,000.00
    $ 99.99
    $ 34.99
    Cleaner
    Pinball Pro
    $ 65.00
    Lighting - Backbox
    Arcade Upkeep
    Pin Monk
    Pinball Mod Co.
    $ 7,599.00
    Little Shop Of Games
    $ 235.00
    RS Technologies
    $ 19.50
    Apparel - Unisex
    ArcadeMade
    $ 63.50
    $ 295.00
    The Art of Pinball
    $ 150.00
    Great American Pinball
    $ 26.95
