OK, here's the story, but DONT read if you're afraid with supernaturel things !!!
still here ?
are you sure ?
OK let's go
well than, in fact no BSD or STh here, i will talk about Oktoberfest
got his pin for nearly 2 monthes, absolute no prob with it, and than today i'll go for a 2nd playfield cleaning...
meanwhile i was busy, i decide to also go under the apron (and this is not part of the story, but i noticed that i have a Bader PF not a Mirco)
cleaning finished, put all back to his place... start button, locked ball(s) ejected to drain, game on, and than i can start...
play ball 1, which goes out, and... nothing ! no new ball in shooterlane, game still active
pin goes in ball search, nothing change
i did eject myself a ball in the shooterlane, play on and OK, ball goes out and same prob again !
let's suppose a software bug, and than try a pin reboot... but same prob again
ok, let's see hardware than
check the rack connector (even if should work as its OK for the very 1st ball) : and yes its OK...
let's check the rack switches : all 6 are OK (all balls are in & detected), the shooterlane works too...
may be pin is "lost" with some bad switches in locks, than i eject ball after ball, and put them in locks, 3 in beer barel, all OK, 3 in the coaster, all OK...
i relaunch the game, all 6 balls are normally ejected, back in the drain, and than i restart the game, play ball 1, goes out, and... same prob again
now i'm swearing... did i have a defective board !?
to be sure, let's now try switch by switch in the rack, i remove the balls from there... 1, 2, 3, 4, 5, 6, 7 ... heu ...
7 !!!!!!!!!!!!!!!!!!!!!????????????????
OF need 6...
now, its time to ask : could you believe than yesterday all was playing OK (with than the needeed 6 balls), and today, i have 7 in the rack ?
few will believe balls have sex (...) during the night !? its badddddd
few others may think there's some magic in this !? shazam !
few more will remain logic : EASY ! its simply the capture ball that escaped from his place... its not ! no broken or missing part, the capture ball is in place...
than what ? do we have some Columbo here ?
(i "forget" a small detail in my story, solution at the end of the day )
