(Topic ID: 270022)
Do you align flippers with rubbers on or off?
By sataneatscheese
1 year ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by zacaj
    #1 1 year ago
    I know where the toothpick lineups are. Do you align rubbers on or off? I alligned off but castle shots and the catapult slam are difficult on MMr.
    #2 1 year ago
    Off, unless someone has better info.
    #3 1 year ago
    Rubbers on and no tooth pick. I eye ball it to line up with the lane guide.
    #4 1 year ago
    Quoted from LTG:
    Yup!
    #5 1 year ago
    I used to use the toothpick with the rubber on stuck between the bat and rubber to help hold it in place.
    Now I just eyeball it rubbers on to the lane guide.
    #6 1 year ago
    As I said, rubbers on! Although after skimming thru other threads on this topic, almost any answer could be considered correct. I do like the "toothpick between the rubber and bat (and into the locating hole) so nothing moves as you raise the playfield to tighten the bat"--that makes a lot of sense. It also seems to me that my TFTC alignment hole was at the tip of the flipper...
    #7 1 year ago
    Quoted from LTG:
    Giving it a shot. Thanks!
    #8 1 year ago
    The hole should be against the back of the flipper bat, disregarding the rubber.
