(Topic ID: 340139)
Do thin rubbers exist?
By Dinsdale
12 months ago
#1 12 months ago
Hi all
I'm looking to add three rubbers to my WWF Royal Rumble where a single rubber exists before. This is to represent ring ropes.
I know I'm going to have to get customised 3D printed star posts with 3 grooves.
But... putting regular rubbers in may be a squeeze and May also impact the strength of the sling.
Do thinner rubbers exist? Ideally Titans...?
This may not be the final answer but it's trial and error.
#2 12 months ago
Just put a larger diameter on.
#3 12 months ago
#4 12 months ago
Yeah I was gonna go with lamb skin but then thought better of it…
#5 12 months ago
I prefer higher sensitivity pinball, just take the rubber off all together.
#6 12 months ago
Scared Stiff enjoys ribbed.
#7 12 months ago
This poor dude is never going to get a straight answer, and somehow thats ok...
#9 12 months ago
Quoted from mrm_4:
You're actually 100% correct on both point points
#10 12 months ago
#11 12 months ago
Quoted from Dinsdale:
Hi all
#12 12 months ago
I endorse this product
#13 12 months ago
Go to a hardware store or and hyd hose place and you should be able to get seals that could be used for what you want. Looking oring-seals that are used for resealing cylinders or matting block.
#14 12 months ago
I'm just glad I didn't name the thread about O-Rings.
#15 12 months ago
Quoted from codered9394:
Thanks, I've actually been looking online for non-pinball silicone o-rings so will try that.
#16 12 months ago
Someone coming in here may blow a gasket with all the Tomfoolery.
#17 12 months ago
Captain O-Ring - Replacement 151122 O-Rings Compatible with Pentair Pentek Big Blue Water Filters OEM Size ORing Buna-N (3 Pack) https://a.co/d/0REokFo
#18 12 months ago
Does ribbing make a difference in performance?
#19 12 months ago
If your talking pinball rubbers use a smaller ring and by being stretched more they get thinner
#20 12 months ago
Quoted from mrm_4:
Dinsdale Welcome to Pinside and thank you for an entertaining thread.
#21 12 months ago
Let's ASSume you want the "look" of boxing ring ropes. I'd skip a star post. If you used a modified star post I think that the
bottom rubber would hit the ball first middle second and top third. On it's rebound chances are it will become an air ball.
Just a guess.
#22 12 months ago
Quoted from FlippyD:
I concur. Have that post go rawdog.
#23 12 months ago
Quoted from vicjw66:
I concur. Rawdog that post.
Just make sure to check your balls often for irregularities
#24 12 months ago
Quoted from LTG:
And a great user name.
#25 12 months ago
I don't think they exist as a pinball part, but you could use an O-ring that is intended for automotive use. The O-ring used on the oil filter canisters of German vehicles come to mind. Smaller diameter than pinball rubber rings and various sizes available .
E79DB3D4-D2A1-4379-9406-0E098D8091D9 (resized).pngE79DB3D4-D2A1-4379-9406-0E098D8091D9 (resized).png
#26 11 months ago
Great replies, think I'll have to buy from a few different sources to get it right.
Quoted from Seamlesswall:
Just a guess.
Yes, this is one of the potential concerns I have too. Though, unfortunately there's only one way of knowing for sure.
#27 11 months ago
I know that in the past I've had some white rubber rings on a game or two, rings that I had purchased new years and years ago that actually *were* very noticeably skinnier than standard white rubber rings. (They all eventually got worn out and tossed.) Haven't seen skinnier ones like that for sale anymore though. I figure that back then they were probably lower priced "economy"-type rubber rings.
$ 28.00
$ 65.00
arcade-cabinets.com
Concord, NC
$ 285.99
PinSound
Professor Pinball
$ 39.00
Arcade Upkeep
$ 16.00
$ 18.95
$ 18.95
$ 18.95
Filament Printing
$ 99.00
Slipstream Mod Shop
$ 32.00
4,375
Ogden, UT
$ 36.95
Hardware
Filament Printing
