(Topic ID: 305534)
Do System 11 games need diodes on all flipper coils?
By n1teowl
1 year ago
#1 1 year ago
I have a High Speed that works fine most of the time, but occasionally will freeze in the middle of a game with GI lights and music still playing but no power to the coils. I have done some research here and see that it might be a coil diode issue on a flipper coil. I took a closer look at my game and see that the upper flipper (which has always been kind of weak) has no diode on the coil. All of the flipper coils in this game are supposed to be the same, and are FL 23/600-30/2600-50VDC. I thought that the missing diode might be the problem so I soldered one in. When I went to try it out, the upper flipper seemed stronger, but the hideouts immediately stopped kicking out. I investigated and found a 2.5 amp slow-blow fuse in the bottom of the head had blown. I cut the diode, replaced the fuse, and everything seems to be working fine now (except back to the weaker coil). I'm assuming that there is supposed to be a diode on that coil, any ideas on what might be happening?
#2 1 year ago
All flipper coils on High Speed will have a coil on them (called a flyback diode) for circuit protection. When the voltage to the coil is shut off, the collapsing magnetic field can generate a voltage spike which can in turn destroy components in your coil driving circuit. The symptoms you described are caused by something else. In fact, having a flyback diode on a coil that doesn't really need it would not cause a problem anyway.
Trying to understand your symptom: When you say freezing, what exactly stops working? Only the coils? You said no power to the coils in this statement - Did you check the coil supply voltage with a meter when this happened? I'm asking these questions because there is a different path to troubleshoot if you have lost supply voltage to the coils, versus if the game stops sending trigger signals to the coils (they have supply voltage but don't fire because the driving transistors are not getting a signal to conduct and complete the coil ground path)
#3 1 year ago
Quoted from wayout440:
Thanks for the reply. Everything stops working when the machine freezes. The background music plays, GI is still lit, but switches and coils stop responding. The ball drains and the background music just plays in a loop. It's similar to this situation:
https://pinside.com/pinball/forum/topic/high-speed-intermittent-lockup#post-5294261
If I turn off/on then everything works normally again. I tested the voltages coming out of the power supply board and they looked good (4.95 volts).
#4 1 year ago
Has the power supply ever been rebuilt w new caps?
#5 1 year ago
Quoted from Blackbeard:
No I don't think so. I was considering doing this as my next step. Could this be the issue even though the voltage check out okay? Might the voltage be dropping later during play?
#6 1 year ago
Quoted from n1teowl:
Not sure.
I always get a ps capacitor kit and rebuild them if they have those old brown caps still. It's SUPER easy to do.
Gweem's Mods
Sound/Speakers
$ 12.00
Benton, AR
$ 54.99
Shooter rods
$ 52.99
Pinball Shark
Shooter rods
Protection
RobTune
Toys/Add-ons
Other
Decals
This page was printed from https://pinside.com/pinball/forum/topic/do-system-11-games-need-diodes-on-all-flipper-coils and we tried optimising it for printing. Some page elements may have been deliberately hidden.
