Do Stern Spike II systems have batteries that need to be replaced or does the SD Card replace the batteries in that system?
Quoted from LTG:
CR2032 - circled with arrow pointing to it.
Wow that's lame. I assumed they had a NVRAM type solution. Is the battery soldered to the board?
Quoted from crujones4life:
It's one that clips in like on motherboards.
Quoted from Brtlkat:
The spike 2 has a BR1225 battery.
How often does it need to be replaced?
Quoted from LTG:
That is not what my motherboard looks like...
Quoted from SWfan:
So look over what you have for a battery. Can't be hard. Easier than me digging further.
Quoted from LTG:
I found it, thanks! It's a coin-style battery turned sideways so I didn't see it at first. Any thoughts on how often to change the battery?
Thanks again!
Quoted from SWfan:
They either have a clip you lift and slide out, or just slide out.
Quoted from SWfan:
Thanks again!
At work we replace the 2032 batteries on a 3 year program. You could probably stretch that much further. I've seen them last in excess of 10 years or more on through hole ram boards.
Quoted from SWfan:
The br1225 about the same as above I would say
5-10 years
5-10 years
Thanks!!
