My guess is that if you connect it the wrong way it will spin in the opposite direction. I'm sure others will give you the correct answer.
Quoted from underlord:Polarity controls motor direction on that unit. You’ll find out soon enough.
Hehe. Ok, so 50% chance it works right. If it doesn't, then turn it off quickly...
Quoted from EvanDickson:Hehe. Ok, so 50% chance it works right. If it doesn't, then turn it off quickly...
Bingo.
If I had TAF I’d send a pic. Those wires look trained to direction. Maybe a clue?
Can you power the motor without connecting to the game. That will give you direction. What voltage does the motor run on?
DC motors are polarized and timed in some cases. when the motor is timed anything other than zero it will turn higher rpm or torque with positive polarity and lower rpm or torque with polarity reversed
probably safe to power it with a 9 in short bursts to determine polarity
It'll spin the opposite way if connected wrong and then blow a fuse on your board. I had the same mistake once.
Quoted from nikpinball:It'll spin the opposite way if connected wrong and then blow a fuse on your board. I had the same mistake once.
Once.
Quoted from EvanDickson:Got it the right way on the first guess.
Thanks y'all.
No fires, no one died...
My work here is done.
8F01D301-852B-48D3-84CC-6EA0DC8E87F3.gifWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/do-motors-have-polarity and we tried optimising it for printing. Some page elements may have been deliberately hidden.
