Do LEDs ghost in WPC-95 inserts like they do in the earlier titles? If so, will the WPC LED patch work? I know I can buy ghost busters but it is cheaper to apply a patch, particularly since I need to upgrade the game ROM anyway.
Thanks,
Dan
Thanks,
Dan
Not really that I've seen and the patch should work ok. Easy to test. Put in one bulb and run the row and column tests and see if the one lamp is slightly on when it should be off.
I don't know about the patch, but LEDs do ghost in WPC-95 games. Depends on the title and quality of the LEDs.
Again, no point in arguing it. Put one led in any controlled lamp and run the lamp row and col tests and see for yourself.
The patch you speak of was extracted from later games. Mid WPC-S games have it from the factory in many cases - so you most likely won't be able to apply it to any WPC-95 games.
This page was printed from https://pinside.com/pinball/forum/topic/do-leds-ghost-in-wpc-95-games and we tried optimising it for printing. Some page elements may have been deliberately hidden.
