I have excessively powered coils in my TZ. The ball-release coil, for example, punts the ball clear over the diverter into the shooter lane. I have bought/installed a few replacement coils, each with a higher resistance than the last, but none has been week enough to release balls properly. I spoke to Steve at The Pinball Resource about this and he suspected my game voltage is somehow excessive. My household voltage is 122VAC and the voltage at the ball-release coil is 77VDC. 77VDC is weird. I looked in the manual to learn more. The ball-release coil is solenoid #9, powered by J127-1 on the Power Driver Board (see photos). When I look at the schematic of the PDB, it shows 50V at J127-1 (see photo). In fact, there is no voltage anywhere in any of the diagrams (excluding the main power diagram) that is more than 50V. I asked a seasoned op about this and he said my coil may meter 77VDC, but it’s actually 50V under load. I metered his coil on his machine and, sure enough, his coil at rest is also above 70VDC. His ball-release coil works fine, however. The stock coil is a 12-2600 with 10 Ohms resistance. The replacement coil in there now is a 30-3000 with 69 Ohms resistance and it’s still too powerful!
Steve told me to consult the manual for information on the “jumpers” in the power box, as these are configured in response to where the machine is on location. In places outside the U.S. where the voltage is different, these jumpers are important. I found nothing in the manual but I did find the three voltage diagrams in the schematic manual (see photo). There appears to be a “strip” in the cabinet for games designed for foreign markets through which one can adjust the game’s voltage management. I have no such strip. Is there any chance my game is a re-import and still set to 100V? If it were set to handle 100V and I’m presently giving it 120V, would that make my coils hyperactive? Any insight into this problem would be much appreciated.
Thanks for reading my long post!
