For those f you that repair these things every day, I have a questions pertaining to coils. I installed a new power board in a Williams game for unrelated reset issues (Caused by heat) that were disclosed when I bought the machine. All was good for a short while, however I quickly lost the transistor on the new board which powers the ball plunger. I traced everything back, and there are no shorts, loose connections, etc. The molex connectors were replaced a while back as well, so I know they are good, and I did not lose any fuses. I replaced the 20A Transistor with exact replacement and lost it again after about an hour of play. Replaced that with a little bit bigger capacity (36A) and all is good. Been playing fine for several days and no issues. Diode on the coil is good, and the coil tested at 3.3 Ohms Resistance, In looking at the original game specs, it appears 20A was the designated transistor value, and it did NOT blow the 20A transistor on the original board, but does on the replacement. These boards do have a reputation for being a bit "hot" on the high voltage side, but for a momentary load such as a ball plunger, It is hard to imagine something in excess of a 20A load dropping the transistor. So for the gurus out there, do these coils degrade over time where the load will increase? Most of my experience has been that they will just short and fail? I figure it is a small price to replace the coil and diode just as PM, but was curious as to others experience? Thanks
