(Topic ID: 324286)
Dmd screen problem
By ababapanos
1 year ago
#1 1 year ago
Hello . I have a problem with the dmd on my creature from the black lagoon. when I play after some time the screen stops showing normally and to fix it, I close the pinball and open it again and then it works normally.
however, the problem does not stop, it happens again and again. what could be wrong?
#2 1 year ago
Looks like bad data. Try reseating all your ribbon cables inside the backbox especially the ones from the CPU to the DMD driver board and from the DMD driver board to the DMD. You do not need to remove the cables, just lift up slightly and push back down.
If that doesn't help might be a bad high voltage section on your DMD driver board or a bad display. Try reseating ribbon cables first.
The last thing we'd try is swapping DMD driver boards and DMDs from your WCS94 game.
#3 1 year ago
^ What he said.
In case your ribbon cables are dodgy, Marco has a set:
https://www.marcospecialties.com/pinball-parts/RC1165
#4 1 year ago
I took the cables out and put them back on the board but it didn't change. he did it to me two other times. I noticed that every 3 games this happens at the end of the third game, after the screen says game over. then if I turn off the machine and turn it on again, it will work normally again.
#5 1 year ago
I'd first swap in the DMD driver board from your other game. If it works, it means that the HV section on the other board is toast. If it still is wonky, swap in the DMD and see if it works. Luckily you have another game with the same parts to figure out what is going on.
#6 1 year ago
The fact that it comes and goes, I’m thinking it’s a cold solder joint(s). Possibly the ribbon cable wiring, but I’d reflow solder on the DMD(especially around where the ribbon cable connects) and also where it connects on the CPU.
If that doesn’t fix it, swap out the ribbon cables. If neither of those fix it, then I’d look to the suggestions above. Make sure your signal path is solid, before troubleshooting boards or components.
I’ve brought back quite a few DMDs, just by reflowing cold solder joints.
#7 1 year ago
So the problem is very strange. . It only happens on the game over screen. when he shows the video with the car and it's interesting, but not every time. and it starts every time it sounds like I won a game
#8 1 year ago
run and test dmd display and give me this all the times
#9 1 year ago
Do what Schudel5 is telling you. Replace your DMD driver board with the one from your WCS94. More than likely your DMD driver board is flaking, particularly the high voltage section. Report back once you’ve tried that solution.
#10 1 year ago
You may have a combination of problems.
1. Outgassed display
2. Low high voltages
3. Failed RAM on the DMD controller.
Best to swap controller boards like schudel5 suggested.
Chris Hibler - CARGPB #31
Http://chrishiblerpinball.com/contact
http://www.PinWiki.com/ - The new place for pinball repair info
8,500
Olive Branch, MS
$ 69.99
$ 45.95
€ 24.00
$ 250.00
Professor Pinball
7,800
West Bloomfield, MI
Lenticular Designs
8,200 (OBO)
Marietta, GA
$ 54.99
$ 399.00
$ 49.99
$ 9.95
$ 259.99
$ 448.00
Juz PINBALL Mods
West Chicago, IL
$ 109.99
$ 29.95
Mitchell Lighting
Metal-Mods
€ 99.00
Lighting - Under Cabinet
Watssapen shop
$ 27.95
€ 25.00
PPmods
$ 38.00
Various Novelties
Pinball Photos LLC
€ 24.50
Pin-Decals
$ 449.00
$ 449.00
$ 1,059.00
