(Topic ID: 141634)
DMD Row 9 is out
By mof
  • 23 posts
  • 7 Pinsiders participating
  • Latest reply 1 year ago by mof
#1 3 years ago
I'm troubleshooting my first DMD display. (I counted down from the top, 1,2,3,4,5...8) then the 9th one is out.
Looking for guidance on how to troubleshoot and resolve.
Looking for best topics in Pinside to review and online resources to review.
At first it was an intermittent problem (10-20 plays ago), and now it's rather consistent.
Game is Getaway.
1. I've reseated the ribbon cable on both ends.
2. I've reseated the other cable on the DMD end -- didn't see yet where to reseat it on the MPU end
-mof
#2 3 years ago
Hard to fix lines out in a dmd, I would Start looking for a new one.
#3 3 years ago
Hmmmmm You have 6796 post, One would think you would have read about these on here already.
#4 3 years ago
If you're missing a single line the vast majority of the time it's a break in the connection at the glass.
https://pinside.com/pinball/forum/topic/fixing-a-dead-dmd-column-or-row-cherry-4205-dmd#post-322440
#5 3 years ago
Quoted from terryb:
Thanks Terry. I wonder how I can test for this. I don't happen to have an extra DMD here. I can see the value in having a working backup.
-mof
#6 3 years ago
Take something pointed and non-conductive and push in on the area where the connection is while the game is on.
#7 3 years ago
Quoted from terryb:
Sounds good. What's a good tool -- seems like a bamboo toothpick is too wide.
-mof
#8 3 years ago
I use orangewood sticks (I've covered these in my soldering guide) or you could fashion something out of a wooden skewer.
3 weeks later
#9 3 years ago
I was able to get a plastic tool and push in there -- I saw row 9 turn on a bit -- so I'm more convinced it's that connection.
-mof
#10 3 years ago
The recommended solution applies if the DMD glass is a pin style as shown in the referenced tutorial.
If it is the ribbon connection style you are generally SOL.
#11 3 years ago
Here's my Cherry DMD:
I put a temp sharpie mark on pin 9.
-mof
#12 3 years ago
The pin you have marked slides between two sheets of glass (at the top after the 90 degree bend) and presses against a copper pad. You will need to expose the copper pad and then epoxy the pin to the pad.
3 months later
#13 3 years ago
Ok, I'm going in...
-mof
Cuts have been made. Pin from board is definitely loose.
-mof
#14 3 years ago
New "L" shaped wire made. (3/8" by 1/4") Time to solder it in place.
-mof
#15 3 years ago
I've lathered on conductive epoxy, in the hopes that will minimize vibrations and hold a good connection.
-mof
#16 3 years ago
It works!
It sure took a while, but it was a fun fix. I hope it holds!
Now to cure the epoxy at 149F for 60 minutes...
-mof
#17 3 years ago
Quoted from mof:
It works!
-mof
Congratulations. That's a delicate repair.
#18 3 years ago
Man that is ugly. But effective and a whole lot cheaper than replacement. I like that in a repair.
#19 3 years ago
Meh, I didn't get enough conductive epoxy underneath the wire, and it must have come loose. I'll give it another shot another day. It is most definitely not a job for an unsteady hand. Difficulty: 9/10.
It *was* working...
-mof
1 year later
#20 1 year ago
I just repaired my Theatre of Magic dead columns using the threads I found here. I didn't drill. I bought a set of dremel glass cutting wheels. The drill is probably the way to go. If I did it again, with the dremel wheel, I'd probably go at it from the side to try to expose the tab. It doesn't take much to contact with the conductive paint. BTW, mine doesn't look like the ones above - but the fix is the same.
Dremmel wheel ($10) - amazon.com link »
Conductive paint ($15) - amazon.com link »
Ultra fine paint brush ($4) - local craft store
So basically $30. Given that I saw some used DMDs at the local pinball & arcade swap meet for $90, and the difficulty of the repair, I'm not sure I'd recommend the fix.
I'd say it's a difficulty 8/10.
#21 1 year ago
Congrats on getting it working. It is a very delicate job.
#22 1 year ago
Quoted from UltraPeepi:
Congrats. This is a scary repair to start. Got any pics?
1 month later
#23 1 year ago
Yeah, I got close but ultimately failed. A friend bailed me out with a free DMD...
The project still sits in a box... It's not over!
-mof
$ 16.50
$ 27.99
Lee's Parts
$ 19.00
Tilted Pinball
$ 28.00
2,750 (OBO)
San Francisco, CA
