So here is the deal, I turn the machine on, everything works for a couple minutes, then the DMD goes out. I start diagnosing, here is what I found out. Looking at the main plug to the DMD, Pin 1 measures 119 V and Pin 2 measures 112 and rising, as soon as it hits 116 V the DMD goes out. I checked the fuses and BR1 on the DMD driver board and all good. I pull the plug off the DMD and Pin 2 measures 94 V.
What is causing this to happen. I looked at Piniwiki and it was starting to get a little confusing, had to stop and come to you guys for advise. Please advise
Chris
