Can I use a DMD out of a Williams machine in a Data East (128 x 32) machine for testing purposes?
I just found this today because of a DMD issue I had. Hope it helps.
Are All Dot Matrix Displays the Same?
The short answer is "yes". But be aware DMDs come in different sizes. Williams
always used the 128x32 column/row variety (DataEast for example used a 128x16
and a 192x64 display, in addition to 128x32). And yes a 128x32 dot matrix display
from a Gottlieb, Sega, DataEast or Stern game will work in any DMD WPC/WPCS/
WPC-95 game or vice-versa (but note that DataEast/Sega/Stern have an
additional controller board bolted to the back of their 128x32 DMD, which is not used
on a Williams WPC game). Also it should be stated that some brands of dot matrix
displays (like Babcock) require 12 volts to operate, and most others don't. I have
seen problems where a DMD requiring 12 volts won't operate in a game, but one that
does not require 12 volts will work.
This page was printed from https://pinside.com/pinball/forum/topic/dmd-interchangeable and we tried optimising it for printing. Some page elements may have been deliberately hidden.
