The image on the display will flicker or sort of bounce around when it gets really bad the image will look somewhat scrambled as seen in the picture. The problem does seem to get more pronounced when there are more machines running but it can be pretty bad even when it's the only one running, but it seems less frequent. My first thought was maybe power supply, I did swap it out and it made no difference. I checked some of the wires going to the dmd boards they look good. Hoping for a little help to narrow down where I should be looking in particular for problems. Thanks
