(Topic ID: 93263)
DMD fixes itself, can some explain how?
By Zippee
  • 12 posts
  • 9 Pinsiders participating
  • Latest reply 4 years ago by Sly_Old_Devil
#1 4 years ago
i have a hrc, i noticed a bumper lite was out, i wanted to see if the problem was with the lite or the socket so i switched the bulb that was out with a bulb in another bumper, now that second bumper lite was out but the first one was working so i knew it was just a dead bulb...then i noticed that a horizontal line on the dmd, fourth from the bottom, was now mostly out, i was urinated because i thought i'd have to replace that now...i didnt have the replacement bulb on hand so i sent away for some and just got them
so i just replaced the bumper bulb that was out and it's fine and guess what, i notice that the dmd is now working fine, the line that was mostly out was now 100% fine...
can anyone explain what happened? obviously the replaced bulb completed some kind of circuit that wasn't complete before and was affecting the dmd and now everything is ok...anyone ever see anything like this before or knows what happened?
#2 4 years ago
Two different things.
The line out on the DMD has a weak or cracked wire/ribbon to that line that was out.
Your working on the game moved things enough so it's making contact again.
Bulb had nothing to do with the DMD.
LTG : )™
#3 4 years ago
Aren't you the guy who started the thread about playing while high?! %-)
That would explain it, perhaps?
#4 4 years ago
but the dmd line didn't go out til the bulb went out and then both came on together, how does replacing the bulb affect the dmd it doesn't make sense
#5 4 years ago
LTG was saying is that the timing is coincidence, not causally related.
-1
#6 4 years ago
ok
#7 4 years ago
Borg technology...
Star Trek, not the designer
#8 4 years ago
Quoted from Zippee:
#9 4 years ago
It just urinates me off when the damn thing fixes itself and I miss a chance to work on it.... rather than play it!
#10 4 years ago
i still don't believe it was a coincidence...both things go out at the same second, and then the second one is fixed the other is fixed
#11 4 years ago
auto correct infuriated???
#12 4 years ago
Quoted from Zippee:
Take the bulb out and see if the dmd line goes out, toggle this a few times and before you know it you'll be doing the hockey cokey, but that should show you that the two are not connected at least.
$ 66.95
$ 399.95
$ 45.00
Pinball Photos
Gweem's Mods
$ 45.00
Pinball Photos
$ 55.00
Pinball Photos
$ 7,499.00
Operation Pinball
$ 69.99
$ 5,799.00
Classic Game Rooms
Playfield - Plastics
Bright Lights Pinball
