OK, I've got an odd issue that I'm struggling to diagnose on my Jack*Bot. It displays garbage (similar to a blown U24 RAM.) Initially it only happened occasionally when the game was on for a couple hours. Then it would happen after half an hour. Now it displays garbage starting as soon as the game boots.
I've swapped the following between my Jack*Bot and Shadow to rule out possible causes of the problem:
DMD
Display controller board
Both ribbon cables
This has me thinking it may be MPU related. (I don't see acid damage.)
The gradual onset tells me it's not that some component failed suddenly (I think) but rather something has gone bad over time, maybe a solder joint or socket somewhere.
I think I'm on the right path, but have hit a bit of an impasse. Any words of wisdom?
