(Topic ID: 246736)
Sega DMD has dim sections on certain frames
By Gogojohnnyquack
    #1 4 years ago
    Hi. I am refurbishing a Sega The Lost World Jurassic Park and have a DMD that behaves strangely. Sometimes it is normal, and other times it has parts dimmed out or patchy. I have replaced the ribbon cables, replaced the DMD with a known 100% one, and checked the power output of the display power supply. While the voltages aren't at the top of the range they appear to be within spec and there is a 12v difference between pins 1 and 2. I took these measurements with the display connected.
    What do the tech gurus here advise?
    Here are pics of what I am talking about..
    Normal behavior in DMD test (vert. line out is the scanning line during the test) and Portals menu:
    Portals menu normalPortals menu normalDMD test normalDMD test normal
    Patchy/Dim behavior at other times:
    patchy switch matrixpatchy switch matrixpatchy version screenpatchy version screen
    #2 4 years ago
    Beuller?
    #3 4 years ago
    Did you reseat all the plugs
    #4 4 years ago
    Appears that DMD is outgassing. The DMD looks to be the easiest out of the games in your collection to remove from Judge Dredd and try out in the game to be sure. You can hold the DMD by the edges of the board and plug it in the game without actually mounting it. Beware not to touch the back of the DMD display when the game is on.
    #5 4 years ago
    Good news is that all the DMD games you have, ColorDMD is available and in color for them all. You could move one of the other DMD (except TWD uses a low voltage LED display) if you were to upgrade a game to color.
    #6 4 years ago
    Yep, outgassing
    As said above , if gotta go new, go color
    #7 4 years ago
    Quoted from PinballManiac40:
    Quoted from dc2010:
    Yep, outgassing
    How is it out gassing if it works 100% in the test mode?
    #8 4 years ago
    Quoted from mrossman5:
    A gut feel, which is why I asked for another DMD to be tried in the game to confirm it.
    #9 4 years ago
    I've never seen an actual display with outgassing - I've only ever seen pictures. Test mode tests the digital logic on the DMD controller board. The logic may tell the display to light up a pixel but the display may not respond correctly. If swapping the display with a known good produces the same results then it's likely to be a voltage problem rather than a digital logic problem.
    What PinballManiac40 said.
    #10 4 years ago
    Thank you all for your replies and advice.
    Quoted from bssbllr:
    Yes, several times, and replaced all of the ribbon cables.
    I took the DMD from Lord of the Rings and it behaves identically.
    Quoted from DumbAss:
    This was my suspicion and I will engage my electron vision and post power supply pin voltages with and without the display connected tomorrow. I have ordered a bunch of components to rebuild the power supply assuming that this will be the issue. The logic appears to function correctly for the rest of the game.
    #11 4 years ago
    Quoted from Gogojohnnyquack:
    With Data East / Sega / Stern (Whitestar) games if you can uncouple the actual display from the controller and swap the actual display that should give you the differential diagnosis.
    JP display with LOTR DMD controller in LOTR should show the problem if the display is bad.
    LOTR display with JP DMD controller in JP should work properly if the display is bad.
    The goal is to isolate the faulty component. There are three variables in play here.
    1) The actual display.
    2) The DMD controller.
    3) The power to the display.
    It seems like the DMD controller (digital logic) is fine. It's likely to be either the actual display or the power supply for the display. If you put the actual display in a known good setup it should point you in the correct direction. If you put an actual known good display in the JP and the power is bad you will see the display not work correctly.
    You can also eliminate the display by using your low voltage display from The Walking Dead but you may need to build a power connector for it as the wiring for the JP will not be compatible. If you have an external power supply (like an arcade or PC PSU) you can grab the +5V off that to power the display. Just be careful that the ground is at the same reference level (should be connected to the ground pin).
    #12 4 years ago
    I believe both the LOTR and the Lost World JP both use the same small DMD power supply. I would swap that next before replacing parts. Board part numbers should be labeled on the boards and in the game manuals.
    #13 4 years ago
    I have installed the DMD from LOTR with identical results. This eliminates the display as the problem.
    I have installed the display power supply from LOTR with similar results. The lower right corner of the switch matrix screen are still dim but they 'fade in'. Other screens show the exact same dim sections as before. Below is a short movie clip showing this effect. This eliminates the power supply as the problem.
    Next I will install the DMD controller from LOTR, which will have eliminated everything except the power supply wires and the display ROM.
    I have wiggled the power supply wires from end to end with no change in behavior.
    The currently installed Display ROM is 201 from IPDB.org, which also comes with the CPU ROM 202 that I have not been able to make work. But that is an issue for another thread.
    6 months later
    #14 4 years ago
    Well, I'm a dumb ass. Not sure what I was doing before but I just swapped in the DMD from #lord-of-the-rings and it works great. Thanks for everyone's help and advice, I'll mark this as resolved.
    This page was printed from https://pinside.com/pinball/forum/topic/dmd-display-dim-at-times and we tried optimising it for printing. Some page elements may have been deliberately hidden.
