(Topic ID: 194883)
DM Upper flipper blowing fuse. Need help Trouble shooting
By rtotans
6 years ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by ForceFlow
#1 6 years ago
I need some trouble shooting for my Demolition Man. I keep blowing a fuse in my Rottendog flipptronic board. (Its for my Upper flipper) There is something shorting it, but I don't know what to look for. The rottendog board looks almost brand new, but I guess that might be an issue. Is there anything else to check for? Basically what happened at first I blew the fuse, so i changed it. it worked for a couple of games, then I blew it again. Then when I put in a new fuse, the upper flipper went up by itself until the fuse blew again. I smelt a little burning the last time. Any advice, I would be extremely grateful. Thanks and have a good day.
#2 6 years ago
You could have a bad transistor on the flip board, or a shorted diode on your coil, or, as happened to me, a screw that was too long that is shorting out an un-wrapped coil, or a shorted coil itself.
I'd start by checking the coil and diodes first then move upstream from there to the flip board.
If you are new to this go to the pinwiki resets it is super helpful.
http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Game_resets
#3 6 years ago
Since this is probably the easiest, measure the coil resistance first and see what you get.
Next, lift up the playfield and look at what happens when the flipper moves, and like buffaloatx said, something may be touching something else when it's not supposed do.
Next, check the transistor with a multimeter. Also check the connector to make sure there aren't any wires popping out or any stray copper hairs from the end of a wire touching neighboring wires. Also check the ribbon cable to make sure the insulation hasn't worn through near the ribbon cable connectors.
If all that seems to check out, then check and/or replace the diodes.
I usually try to troubleshoot according to a combination of what is easiest to check and rule out, and what is most likely to cause a problem.
$ 72.95
$ 329.99
$ 18.95
Metal-Mods
$ 40.00
$ 85.00
4,600
Ponte Vedra Beach, FL
4,690 (Firm)
La Porte, TX
3,700 (OBO)
Monroe Township, NJ
$ 39.99
Mitchell Lighting
$ 40.00
Nezzy's Pinball Prints
$ 65.00
YouBentMyWookie
3,250
Bethlehem, PA
$ 35.95
Mitchell Lighting
$ 54.95
$ 18.00
Volcano Pinball
$ 45.00
86Pixels
$ 81.95
This page was printed from https://pinside.com/pinball/forum/topic/dm-upper-flipper-blowing-fuse-need-help-trouble-shooting and we tried optimising it for printing. Some page elements may have been deliberately hidden.
