(Topic ID: 250333)
DIY Playfield post repair and chip proofing. How To all brands
By Yelobird
  • 280 posts
  • 93 Pinsiders participating
  • Latest reply 6 months ago by VisitorQ
  • Topic is favorited by 194 Pinsiders
There are 280 posts in this topic. You are on page 6 of 6.
#251 2 years ago
Quoted from Spelunk71:
Just FYI, the iron caused the clear to crack around one of my posts. It was probably my fault for leaving the iron on too long (everyone else seems to have had great results), but be careful!
Yes,the iron has no thermostat so it just gets hotter and hotter. Unplug it and cool it down frequently. The least heat possible to do the job is what you want.
#252 2 years ago
Quoted from Shmilder:
Can someone post a link to the iron. I'm in Australia but can't find one anywhere, here or international.
Just be carefull. Due to the chemicals in the kit I had two irons returned by Aus Customs. Had to ask the seller to remove chemicals and just send Iron to finally get one here.
#253 2 years ago
just thinking aloud here but maybe the ironing doesnt only harden the clear enough to not crack up again but may it also make the inking better stick to the playfield? if so this could also be used as a preventive measure in a new game with playfield susceptible to pooling and chipping?
#254 2 years ago
Putting Mylar washers on my GNR SE this weekend. No pooling on mine. Arrived fall last year.
#255 2 years ago
Quoted from MeesterPieter:
I would not be able to verify that though I suspect the applied ink is not an adhesive layer so likely would not be assisted. If however they are base coating the playfield with a layer of cure Then applying ink then possibly it could assist to adhere there.
#256 2 years ago
Where do you get the Mylar washers?
#257 2 years ago
With all of the continuing playfield issue threads it Sadly appears this problem is still far from resolved at the OEM level. While this repair Does work very well I do want to Strongly suggest a preemptive suggestion to hopefully avoid doing this repair in the first place! When you get your game take 15 minutes to pull the primary posts at the slings and install mylar protectors Before the damage appears! While not a 100% guarantee I feel certain this preemptive measure will drastically reduce the probability. Having the surface bonded as one large layer should help prevent it from spreading independently and reduce the probability of that surface rolling and eventually cracking! Again, just an opinion and yes does not seem fair that we need to service a New machine but it is what it is for now. Good Luck!
#258 2 years ago
Quoted from NightTrain:
I wanted to Avoid this as I did NOT want this help thread to come across as a Sales thread but due to Soooooo many emails we are going to offer these on our site for as Cheap as we can. No Profit! Just to hopefully entice people to preemptively try to prevent this. Will be listed today.
#259 2 years ago
I -strongly- advise against this.
I had some art lifting under a post on Wonka CE - it was otherwise perfect (no pooling etc) and I decided to iron it down as a "pre-emptive" fix.
The first time I did it, it worked. The second time, I overheated it and the clear lifted and cracked.
It's fortunately not in a gameplay area and I bought myself a playfield anyway because we play the everloving crap out of that game, so I'm gruntled.
Let my mistake inform others: never fix what isn't broken, beware the iron heat, only iron if you're pooled and need to do it to arrest damage.
#260 2 years ago
Quoted from zaphX:
Agreed. Preemptive just install Mylar we are not making a grilled cheese here! Also, the iron does Not have a temp gauge. Prepare the area Then plug in the iron. It should be overly warm Not lava hot! The only people that said they had an issue let the iron heat for 5 plus minutes then tried to repair. Do not do that! Plug it in and use within 60 seconds. When repaired Unplug it to cool.
#261 2 years ago
Quoted from Yelobird:
Definitely unplug it between applications. It's a very crude device and will just heat and heat and heat.
#262 2 years ago
THANK GOD. Nothing will make me happier than someone else offering mylar washers. People were ordering like a Small and a Medium 10 pack before. Now, with this GnR fiasco, people are ordering like ten 10 packs at a time. It's crazy. Tons of backorders because I just wasn't ready for the massive volume spike. More than happy to have you take the Mylar washer mantle.
#263 2 years ago
I went to your site to buy some and could not find them. Just some feedback from a old guy.
#264 2 years ago
Quoted from JohnTTwo:
Sorry not old I am just Slow... lol I promise to have them up Tonight.
#265 1 year ago
A product we are sad to offer but unfortunately for now you have to protect your investment. These mylar rings can be used after playfield repair using an iron etc. I however STRONGLY suggest using these to protect the playfield post areas BEFORE damage happens! A preemptive solution. Very simple to install and while not guaranteed has proven to mitigate or avoid issues long term which are often not reversible once the damage is done. Take a few minutes to protect your investment! This size was designed to support Both large and small playfield posts. You do Not want anything smaller as the goal is to bond that mass area as one so it stays together and does not pool up or allow the post to bite in or twist the surface area. Kit is sold as a pack of (10) which should be enough for most any game. Free US shipping on this kit!
www.TheModCouplePinball.com
IMG_6879 (resized).jpgIMG_6879 (resized).jpgMylar_1 (resized).jpgMylar_1 (resized).jpg
#266 1 year ago
If the iron just hearts up forever, my ghetto heat gun / measuring cup idea is probably better because the heat is so controlled.
See post 192: https://pinside.com/pinball/forum/topic/diy-playfield-post-repair-and-chip-proofing-how-to-all-brands/page/4#post-5527572
5 months later
#268 1 year ago
Because your leather heating tool isnt available in France i made my own.
it is made of brass turned on a metal lathe and designed to be mounted on a conventional soldering iron.
I will do some test to know if it works !
16371742711027226299469432029104 (resized).jpg16371742711027226299469432029104 (resized).jpg
16371742940994646543293548737052 (resized).jpg16371742940994646543293548737052 (resized).jpg
#269 1 year ago
Quoted from Jjlp:
#270 1 year ago
I got a cheep iron needed while on a trip and noticed it included a flat thumb sized tip that would work for pooling repair. Of coarse it would get too hot over time like the other tools, but it will work if you unplug it to regulate the temperature. ($18 at Lowes)
1 month later
#271 1 year ago
I don't really think you need an iron for JJP playfields (at least for mine anyway). I just used a hair dryer for a few seconds on the area of pooling then tightened the PETG washer down. When I raised the PETG washer again all was completely flat.
I just mentioned this because it may be unnecessary for people to be searching for and paying for irons when the fix is likely as easy as a common hair dryer.
#272 1 year ago
Quoted from Drac:
Glad you got it all fixed. The direction of this thread was in hopes that owners Addressed the issue and provide a suggested start point to do so. I can say for a fact ignoring this issue Always gets worse! Once it fails and chips its to late unfortunatly. The iron used (in first post) cost near nothing compared to what we spend on general pinball items lol. A hair dryer can absolutely work but I personally found it heats a much larger area vs the controlled press approach. Will that matter? Don't know but also didn't want to find out fixing other peoples games... My Hope is that we Never need to use this iron tool or technique ever again! Unfortunately I have had to use this on more playfields (not only JJP) then I care to mention. Really late update but with a year in none of the repaired then mylar ring sealed fixes none have had an issue since.
#273 1 year ago
Quoted from Neal_W:
My 40 watt Weller solder station has adjustable output. This 20 watt iron should plug right in and work.
$17.00 on Amazon...
amazon.com link »
1 month later
#274 1 year ago
Quoted from Mr_Outlane:
$17.00 on Amazon...
amazon.com link »
This seems like a great idea, assuming that a weller wood burning tip would screw into their soldering iron. It's a shame I can't just buy the tip. Went to Weller's site and had no luck either.
#275 1 year ago
Quoted from Broohaha:
No no, just plug in the Weller woodburning iron into the Weller solder station shown here.. I have a couple different irons for mine.. See various pics...
amazon.com link »
1 month later
#276 1 year ago
So, can a first run game like JP, where this issue was present everywhere, be fixed this late in the game? 3 years or so with the pooling. Worried removing any posts will just pull/chip up the pooling art/clear before you can even try the iron. Anyone do the repair on a game after it has had this damage sitting for a couple years plus?
#277 1 year ago
Quoted from RC_like_the_cola:
I had slight pooling on a game from 2018 and pulled the posts and did this in September 2021, but your game may be different. Just don’t keep the iron on the pooling location for too long. Less is definitely more here. You can always go back and do it again once it cools down.
6 months later
#278 7 months ago
If you choose to purchase the Permatex Vinyl and Leather Repair Kit please read what is included in the package. MAKE SURE IT HAS A "HEATING TOOL" IN IT NOT A "HEAT TRANSFER TOOL". There are several renditions of this kit and you need to buy the correct one. Preferably the "Ultra Complete Repair System". Just FYI.
Thanks to Yelobird for coming up with this technique.
I used a combo of ironing, clearcoat on the areas that were cracked or chipped and mylar rings (Pin Monk) or Clifffy's carbon fiber rings depending on what was going on in that particular area.
I had no idea it was so bad and really involved every post until I started a major shop job on my IMDN Pro. Some posts I really could not appreciate the extent of the damage until I removed them.
#279 7 months ago
Yes. As stated above I am now in the process of ironing/repairing all the post areas on my Iron Maiden Pro. I actually did not pull anything up when removing but each post/game is different, so assess each one and approach it accordingly. Some come right up. Some need a little massaging.
1 month later
#280 6 months ago
Quoted from Neal_W:
I own this iron as well so I have the tip. Has anyone used this particular iron with success? My concern is it's called "Woodburning Kit", I'm not looking to burn anything. I am afraid this may get too hot when compared to the vinyl iron shown in the original post. I also have an adjustable temp soldering iron that may accommodate the brass tip and if so, what temp do I set the iron too?
$ 49.99
Toppers
$ 14.95
Toys/Add-ons
8,299
Oakdale, CA
$ 259.99
Toppers
Playfield - Plastics
Pin Monk
Plastics
9,700
Galt, CA
$ 19.00
The MOD Couple
Toys/Add-ons
6,250
Gray, TN
$ 130.00
Dijohn
Decorations
Decorations
This page was printed from https://pinside.com/pinball/forum/topic/diy-playfield-post-repair-and-chip-proofing-how-to-all-brands/page/6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
