I've had a few requests to make a new topic post on my DIY flipper coil fans... so here it is.
I am not trying to take any business away from modders who offer quality products. If you prefer easy to install solutions with all the parts you need, then the coil fan kits available on Pinside will work great for you.
If like me, you wanted to add coil fans to several games, a DIY approach was required to keep costs lower. I’m a tinkerer by nature anyway…
I have noticed the effects of flipper fade on some of my Stern machines because I often play sessions of multiple hours consecutively on the same machine. My single longest game of pinball to date was 90 minutes on AIQ and fans help considerably on that game! Once I saw and felt the effects of fan cooling the flipper coils (I’m in the Chiller system manufacturing business, so keeping the coils cooled to help maximize performance always made sense to me) I wanted to do it to all of my Stern machines as one of my first mods when I get them, so I don’t have to worry about flipper fade.
My DIY design is pretty simple and you don't need a 3D printer. For Stern Spike 2 machines - I use 40mm 12VDC fans with a rubber bumper mounted to it to allow space for airflow, loosely tie wrapped directly to each coil. Wire to 12 VDC at CN6 on the backbox power supply. I use a 1 amp fuse and also a diode for protection on the power line that feeds all of the fans.
I’ll soon be adding posts to show what parts I use. It becomes more cost effective, basically the more pinball machines you need to add fans to since some of the items you need to buy have some minimum quantities.
If you have questions, your own success stories or your own way of cooling flipper coils – this is the place to discuss it. I’m starting with Stern Spike 2 machines, but all pinball machines are open to discussion.
