(Topic ID: 253917)
DIY: 'LISY', a replacement MPU for Gottlieb, Bally & Stern
By bontango
  • 1,419 posts
  • 93 Pinsiders participating
  • Latest reply 4 hours ago by ThatOneDude
  • Topic is favorited by 118 Pinsiders
    There are 1,419 posts in this topic. You are on page 29 of 29.
    #1402 38 days ago
    Which logs are going to show the pinmame errors?
    #1403 28 days ago
    bontango thanks for the work on these! see system 11 is now a thing but only "c", What would we need to do for a B game? think theyre backwards compatible but not the the other way " IE "C" cant be used in a "B", BUT "B" can use a "C".
    #1404 28 days ago
    Quoted from hockeymutt:
    System 11C MPU boards do not have the sound section(s) earlier MPU boards had.
    From https://www.actionpinball.com/tech/sys11revs.php :
    System 11 boards have all the circuitry on them that the later boards used, with the exception of the 3 LED's to the right of the battery holder- this is a 7-segment LED "digit" on System 11 games, but still works fine in the later games that this board is compatible with. System 11 boards also have some extra circuitry that uses the top left corner 4-pin connector for some of the speakers. Some/all later System 11 boards may not use this.
    System 11A boards: No notes at this time.
    System 11B boards use 3 separate LEDs for board diagnostics, instead of the earlier 7-segment display digit. They also do not have the speaker circuitry and 4-pin connector in upper left corner, as used by System 11 games.
    System 11C boards do not have the speaker circuitry or connector in upper left corner, nor any of the speech processing circuitry in the upper left section of the board- this area is left unpopulated, and sounds/speech in these games are controlled entirely via the background sound board, mounted above the MPU board in the backbox.
    Some compatibilities between versions:
    System 11 boards can be used for System 11, 11A, and 11B boards. For example, we have successfully used a Road Kings board (11) in a Black Knight 2000 game (11B).
    System 11A boards can be used for System 11 and 11A games.
    System 11B boards can be used for Systems 11A, 11B, and 11C.
    #1405 28 days ago
    Quoted from Zigzagzag:System 11C MPU boards do not have the sound section(s) earlier MPU boards had.
    Correct, I have foreseen sound on WillFA11 but need to program and test the emulation for the soundboard.
    But at the moment I work on integration of data East games with DMD. Tests looking good so far but a bit of HW modifikation is needed.
    I will publish WillFA v0.92 which will support DMD games.
    Once (almost) all SYS11C and DE games are tested I will try the sound emulation.
    #1406 22 days ago
    Greedy me would sure like to see System 11, 11A, 11B at some point.
    #1407 22 days ago
    Anyone have a couple or three LISY35SMD boards they want to part with?
    Also looking for Atari Display boards, combined Score & Match/Credit display (LCD) for Atari...
    And last but not least Diag board for WillFA7
    Thanks!!!
    #1408 18 days ago
    Hi all, I am ordering a batch of fully assembled GOSOF (Gottlieb Soundboards) with 'LISY dev' DIY Altera Cyclone II boards made by JLCPCB. Does anyone else want one from this lot? If so DM. I am US based so it would only make sense for folks in North America.
    #1409 17 days ago
    Quoted from radix:
    I'd probably be down for at least one of each.
    #1410 17 days ago
    Hey folks - BallyFA MPU question:
    Have any of you been successful selecting the "hacked" ROMs to run 7 digit scoring in games like 6M$M and Star Trek?
    I have been able to get the later releases to work like, Harlem Globetrotters and Viking - but for some reason no joy with the aforementioned titles.
    Similar issues with Free Play, but I just learned there is a DIP setting requirement along with at least a credit on the game for this hack to work.
    Thanks for any input.
    #1411 17 days ago
    Quoted from Phoerber:
    Have a look to Appendix B of the BallyFA Manual https://lisy.dev/media/files/ballyfa_user-manual_v1.19.pdf
    I copied all the descriptions from Okaegis roms here
    Freeplay:
    if dip switch 17 = on and dip switch 18 = on and dip switch 19 = on
    freeplay is enable: decrease credits not lower then 01
    7digit is usually activated with dip21 = ON
    #1412 17 days ago
    #1413 17 days ago
    Nice! Doing something for Zaccaria would be a welcome addition as there are people that need MPU boards. Lots were damaged by leaking batteries.
    #1414 13 days ago
    Quoted from Robotworkshop:
    Theres a guy making them already. We put the mpu and sound board in Time machine and they work perfect.
    #1415 13 days ago
    Quoted from PinBallPeteFromSD:
    Interisting ... can you provide a link to the product?
    #1416 13 days ago
    Quoted from bontango:
    https://www.pinballsolutions.eu/product-category/zaccaria/
    #1417 24 hours ago
    Hi all,
    I have gotten my order of GOSOF boards in, programed all their FPGAs and gotten the amps and MP3 players. I tested them all in my The Amazing Spider-Man and I am happy to say they all work great.
    I have a few extra boards sets with all parts and am willing to sell them basically at cost if folks are interested please PM me. I am based in the US so probably would not make sense for folks outside North America because of shipping.
    #1418 4 hours ago
    Debug from Night moves
    LISY basic DEBUG activ
    [125.620043][0.000020] LISY DEBUG timer set
    [125.620425][0.000382] Info: udp switch reader server for debug mode succesfully started
    [125.620456][0.000031] LISY Hardware init start
    [125.620471][0.000015] display PIC init start
    [126.223721][0.603250] Software Display PIC has version 6.0
    Info: LISY Hardware: Revision 320 ; HW ID is 2
    [126.525348][0.301627] coil PIC init start
    [127.128455][0.603107] Software Coil PIC has version 5.2
    [127.430022][0.301567] K3 Coil PIC returns 3
    [127.430070][0.000048] switch PIC init start
    [128.994084][1.564014] Software Switch PIC has version 4.1
    [128.994240][0.000156] LISY option: debug
    LISY80: Throttle value is 1000
    LISY80: we are emulating Game No:61 nmoves
    info: trying to parse: /usr/local/share/xpinmame/xpinmamerc
    info: trying to parse: /root/.xpinmame/xpinmamerc
    info: trying to parse: /usr/local/share/xpinmame/xpinmame-vid_lisyrc
    info: trying to parse: /root/.xpinmame/xpinmame-vid_lisyrc
    info: trying to parse: /usr/local/share/xpinmame/rc/nmovesrc
    info: trying to parse: /root/.xpinmame/rc/nmovesrc
    Info: internal Hardware revision is 320
    LISY80_SIG_HANDLER: SIGUSR1 catched
    This is LISY (Lisy80) by bontango, Version 528 93
    Info: checking for Coil min pulse time extension config
    LISY80: opening /boot/lisy/lisy80/coils/061_lisy80_coils.csv failed Info: no coil opts file; or error occured, min pulse time extension disabled
    loading rom 0: nmovsp2.732
    loading rom 1: nmovsp1.764
    done
    lisylogger exit
    This is output of ifconfig and hostapd
    eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
    ether b8:27:eb:34:96:0f txqueuelen 1000 (Ethernet)
    RX packets 0 bytes 0 (0.0 B)
    RX errors 0 dropped 0 overruns 0 frame 0
    TX packets 0 bytes 0 (0.0 B)
    TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
    lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
    inet 127.0.0.1 netmask 255.0.0.0
    loop txqueuelen 1000 (Local Loopback)
    RX packets 36 bytes 2900 (2.8 KiB)
    TX packets 36 bytes 2900 (2.8 KiB)
    wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
    ether b8:27:eb:61:c3:5a txqueuelen 1000 (Ethernet)
    ● hostapd.service - Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
    Loaded: loaded (/lib/systemd/system/hostapd.service; disabled; vendor preset: enabled)
    Active: inactive (dead)
    #1419 4 hours ago
    bontango it looks like his log shows the rom being loaded, but it still errors out on the display. Any thoughts?
