Quoted from bontango:Is the Error LED on?
Can you make a debug log?
As said, working for me .. so maybe something on your PCB?
I would double check all components around the I2C bus ( e.g. orientation and value of R4 )
Yes, the error LED is on together with the LiSY80 LED.
If there is a fault on the PCB, how come the Pi3A+ is working perfect?
here is the debug text:
LISY basic DEBUG activ
[141.675366][0.000073] LISY DEBUG timer set
[141.676131][0.000765] Info: udp switch reader server for debug mode succesfully started
[141.676424][0.000293] LISY Hardware init start
[142.279018][0.602594] Software Display PIC has version 6.0
Info: LISY80 Hardware: Revision 320 ; HW ID is 2
[143.182887][0.903869] Software Coil PIC has version 5.2
[143.484226][0.301339] K3 Coil PIC returns 3
[145.002365][1.518139] Software Switch PIC has version 4.1
[145.002836][0.000471] LISY option: Freeplay
[145.003112][0.000276] LISY option: debug
LISY80: Throttle value is 1000
LISY80: we are emulating Game No:40 bountyh
info: trying to parse: /usr/local/share/xpinmame/xpinmamerc
info: trying to parse: /root/.xpinmame/xpinmamerc
info: trying to parse: /usr/local/share/xpinmame/xpinmame-vid_lisyrc
info: trying to parse: /root/.xpinmame/xpinmame-vid_lisyrc
info: trying to parse: /usr/local/share/xpinmame/rc/bountyhrc
info: trying to parse: /root/.xpinmame/rc/bountyhrc
LISY80_SIG_HANDLER: SIGUSR1 catched
This is LISY (Lisy80) by bontango, Version 527 39
LISY80_SYS_ERROR:6 >Failed to write to the I2C bus display pic (121:Remote I/O error)
[145.489279][0.486167] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:86
[149.497042][4.007763] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:86
[150.499260][1.002218] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:86
[150.500023][0.000763] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:86
Info: checking for Coil min pulse time extension config
LISY80: opening /boot/lisy/lisy80/coils/040_lisy80_coils.csv failed Info: no coil opts file; or error occured, min pulse time extension disabled
loading rom 0: prom1.cpu
done
[151.745532][1.245509] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:85
mpudips return: 01000000 for switch:0
[151.794929][0.049397] LISY80: DIP switch settings according to /boot/lisy/lisy80/dips/default_lisy80_dips.csv
mpudips return: 11000001 for switch
[151.797025][0.002096] LISY80: DIP switch settings according to /boot/lisy/lisy80/dips/default_lisy80_dips.csv
mpudips return: 11011011 for switch:2
[151.797970][0.000945] LISY80: DIP switch settings according to /boot/lisy/lisy80/dips/default_lisy80_dips.csv
mpudips return: 11111111 for switch:3
[151.798222][0.000252] LISY80: DIP switch settings according to /boot/lisy/lisy80/dips/default_lisy80_dips.csv
[151.805632][0.007410] NVRAM delayed write initiated by GAME OVER Relay
[151.839757][0.034125] NVRAM delayed write initiated by GAME OVER Relay
[151.864837][0.025080] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:87
[155.922333][4.057496] NVRAM write DONE
[156.532665][0.610332] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:87
[156.558519][0.025854] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.193787][0.635268] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.194679][0.000892] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[157.218025][0.023346] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.218722][0.000697] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[157.219395][0.000673] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[157.241367][0.021972] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.242090][0.000723] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[157.264397][0.022307] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.287221][0.022824] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.287936][0.000715] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[157.288610][0.000674] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[157.334339][0.045729] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.335032][0.000693] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[157.358165][0.023133] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.358852][0.000687] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[157.418193][0.059341] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.441492][0.023299] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.509688][0.068196] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.555032][0.045344] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[157.555716][0.000684] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[159.873971][2.318255] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[159.910611][0.036640] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[159.956232][0.045621] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[160.001314][0.045082] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[160.023379][0.022065] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[160.048298][0.024919] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[160.048988][0.000690] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[160.049658][0.000670] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[160.050354][0.000696] ERROR: lisy80_write_byte_pic(Display Pic): repeat:4 for byte:4
[160.051039][0.000685] ERROR: lisy80_write_byte_pic(Display Pic): repeat:5 for byte:4
[160.073421][0.022382] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[160.154567][0.081146] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[160.177454][0.022887] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[160.178153][0.000699] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[160.200195][0.022042] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[160.200901][0.000706] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[160.201575][0.000674] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[160.202236][0.000661] ERROR: lisy80_write_byte_pic(Display Pic): repeat:4 for byte:4
[160.271881][0.069645] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[160.399285][0.127404] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[162.715232][2.315947] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[162.758883][0.043651] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[162.759364][0.000481] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[162.759830][0.000466] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[162.760296][0.000466] ERROR: lisy80_write_byte_pic(Display Pic): repeat:4 for byte:4
[162.785198][0.024902] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[162.785679][0.000481] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[162.786146][0.000467] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[162.786613][0.000467] ERROR: lisy80_write_byte_pic(Display Pic): repeat:4 for byte:4
[162.787082][0.000469] ERROR: lisy80_write_byte_pic(Display Pic): repeat:5 for byte:4
[162.844992][0.057910] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[162.845471][0.000479] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[162.911269][0.065798] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[162.911753][0.000484] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[162.912218][0.000465] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[162.958788][0.046570] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[163.003142][0.044354] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[163.003622][0.000480] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[163.129102][0.125480] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[163.129579][0.000477] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[163.153673][0.024094] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[163.154136][0.000463] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[163.154589][0.000453] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[165.424970][2.270381] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[165.425444][0.000474] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[165.425911][0.000467] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[165.426376][0.000465] ERROR: lisy80_write_byte_pic(Display Pic): repeat:4 for byte:4
[165.426838][0.000462] ERROR: lisy80_write_byte_pic(Display Pic): repeat:5 for byte:4
[165.491631][0.064793] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[165.492106][0.000475] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[165.492568][0.000462] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[165.493035][0.000467] ERROR: lisy80_write_byte_pic(Display Pic): repeat:4 for byte:4
[165.493495][0.000460] ERROR: lisy80_write_byte_pic(Display Pic): repeat:5 for byte:4
[165.494017][0.000522] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte
[165.494482][0.000465] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte
[165.577525][0.083043] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[165.578007][0.000482] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[165.665896][0.087889] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[165.666399][0.000503] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[165.666865][0.000466] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[165.667331][0.000466] ERROR: lisy80_write_byte_pic(Display Pic): repeat:4 for byte:4
[165.712717][0.045386] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[165.713197][0.000480] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[165.713661][0.000464] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[165.795399][0.081738] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[165.795879][0.000480] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[165.907366][0.111487] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.176923][2.269557] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.220289][0.043366] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.281756][0.061467] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.282236][0.000480] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[168.325883][0.043647] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.348402][0.022519] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.348878][0.000476] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[168.392698][0.043820] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.393176][0.000478] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[168.442252][0.049076] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.476719][0.034467] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.477191][0.000472] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[168.477650][0.000459] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[168.478102][0.000452] ERROR: lisy80_write_byte_pic(Display Pic): repeat:4 for byte:4
[168.478550][0.000448] ERROR: lisy80_write_byte_pic(Display Pic): repeat:5 for byte:4
[168.479053][0.000503] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte
[168.523090][0.044037] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.523570][0.000480] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[168.666240][0.142670] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[168.666716][0.000476] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[175.497819][6.831103] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:87
[175.498299][0.000480] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:87
[175.498767][0.000468] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:87
[175.499228][0.000461] ERROR: lisy80_write_byte_pic(Display Pic): repeat:4 for byte:87
[175.499689][0.000461] ERROR: lisy80_write_byte_pic(Display Pic): repeat:5 for byte:87
[175.522489][0.022800] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:87
[176.178920][0.656431] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[176.179396][0.000476] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[176.179864][0.000468] ERROR: lisy80_write_byte_pic(Display Pic): repeat:3 for byte:4
[176.180325][0.000461] ERROR: lisy80_write_byte_pic(Display Pic): repeat:4 for byte:4
[176.271558][0.091233] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[176.322679][0.051121] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[176.323159][0.000480] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[176.352192][0.029033] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[176.352670][0.000478] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
[176.376943][0.024273] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[176.421090][0.044147] ERROR: lisy80_write_byte_pic(Display Pic): repeat for byte:4
[176.421808][0.000718] ERROR: lisy80_write_byte_pic(Display Pic): repeat:2 for byte:4
