Quoted from winteriscoming:Any idea of the pulley size on the stock ICB?
Also, a diameter measurement on both parts of the telescoping rods would be helpful. Is there an obvious bump from one rod to the other when playing or was the larger taper down slightly at end? If tapered, a DIY scenario is going to require some sanding/filing.
Quoted from XXVII:I'll take a look when I get home. I won't be able to get a precise measurement on the rods because all I have at hand is a ruler.
Quoted from Fortytwo:The rods don't have any taper. Just a fit between them both.
Verifying Fortytwo's statement. I just checked my machine and there's no taper. The larger of the two rods seems to be 3/8" in diameter.
The pulley wheel diameter is about 1.75". The thickness is 1cm, with an inner groove of 8mm. The center of the top pulley wheel is separated from the center of the bottom pulley wheel by 28".
The guide rail is 0.25" in diameter, and it seems to be 28" in height.
Quoted from Fortytwo:Don't over think this. It's not a precision machine expensive linear bearings are not nessassary. A nylon chunk with a hole would be more than enough. It's not fast moving to require a bearing.
I agree. If the weight, reliability, or quality of the bearings become an issue, I recommend we go with the hole in the block method. I think the piece that connects the pulley to the telecoping rod should be 3D printed, whether in full or with screw points for these cheap bearings winteriscoming has found.
