With ColorDMD releasing the Sigma 2.2 ROM today, I had everything I needed to build a cable and finally install a blue DMD in my Tron. This is my own method, and is NOT approved by ColorDMD. They may have better suggestions.
Anyway, first you need to build a power cable. It's a 3-pin 0.93" standard plug on one end and a 4-pin 0.156" pitch on the other. I used an IDC connector since that was what I had, but you could use crimp connector instead.
Be sure to get the voltages hooked up correctly. My cable has been verified to work, so if you follow this color scheme, you should be ok. Use 18 AWG wire. Use a key plug in pin 1 of the 0.156" connector. 7 ft long is about right.
Inside the coin door, on the right side, this connector is where the 3-pin 0.093" connector plugs in. It's the same connector as used by many other Stern mods. You might need a splitter, and the FTS-8 available at http://dkpinball.com or Pinball Life is a good option.
