Quoted from Thatguyatelkton:My brother has a mystic gate that has a small but annoying problem. When press a b c after 5th ball is lit, lines will move but will not pay out.
there's no way to explain that looking at the schematic. Payout is enabled when the B-4 trip relay trips, which happens when the 4th ball is shot assuming no balls fell into the return hole. First check is look and see if the B-4 trip relay is tripped.
the B-5 trip relay just disables moving the lines when the 5th ball is shot, and if the selection feature unit is stepped all the way up, the lines can always be moved.
I guess I'd:
1] reset game, shoot 5 balls and set up a win in a color
2] push R button to collect win
3] manually reset the replay counter unit for the winning color (replay counter is a stepper unit, not the replay register that shows the credits)
4] manually step up the selection feature unit all the way
5] push R button again to see what happens
6] manually step up the mystic lines feature unit all the way to enable ABC, move lines and go to step [3]
he does know that if you already collected a win in a color, you don't get paid for different numbers in the same color unless there's more numbers lit, right?
the unusual thing about mystic gate is the program wipers and scramble wipers do not move as the game is coined after reset. Score advance on each of the 40 (max) coins is predetermined.
feature enable is a different story. The more often you can get the reflex relays to power, the more often score doubling or ABC will enable.
you probably want the reflex unit 6-finger span of wipers more-or-less pointing up, but I don't have a diagram for the unit ... haven't convinced anyone with the game to remove the contact plate and take a picture of the wiring side yet
see http://bingo.cdyn.com/techno/howto/reflex_wipers/
if score advance behavior isn't changing, make sure the scramble and program wipers are changing positions every game.
the program wipers spin when the B-4 trip relay is tripped and stop when the B-5 trip relay trips. The scramble wipers move when the shutter panel slides open to dump the balls.
I guess the idea was to try and claim the gambling element was removed since the outcome of each coin played is not random ... at least for scores. If the reflex factor wipers can move a random amount on each coin play, then there's still some gambling involved in feature enable - but I guess they could claim that just a bonus while the scores are advancing.
