Hi there,
I have been having an issue for a while with my swords of fury; the diverters are need several games before they start working.
So it looks like a component is in need of a warm up and should be changed.
Any idea of what I should check?
Hi there,
Probably the coil plunger is dirty or gunked up. Take the plunger out and clean it and polish it. Also, replace the coil sleeve. This should make a big difference.
Quoted from KenLayton:Probably the coil plunger is dirty or gunked up. Take the plunger out and clean it and polish it. Also, replace the coil sleeve. This should make a big difference.
Nope, game was fully rebuilt recently (along with coated pf etc) and every part was cleaned, every sleeve was changed...
It really feels like a component needing to warm up.
Both diverters will start workign at the same time.
I think Ken is probably onto something here.
When you say the game needs several games to start working - what if you fire the game up and leave it sit idle for 30 minutes. Then start a game do they work normally then?
If so Kens probably right about a potential cold solder joint. Look in the manual. Do the offending coils share the same circuitry?
You could also try performing a factory reset.
if the game is iddle, they'll still need several games before warming up. Looks like they need to be triggered for it to happen.
Cold joint is indeed an option; For the circuitry, I don't know unfortunately, thus my question here
Go into test when you turn it on and see if they work in solenoid test. There's some dumb rules in the code that activate/don't activate the diverters depending on various factors.
The lights that are on the ramp covered with the red bulb covers tell you which diverter should activate. You can see them move around as you play and hit various things.
This page was printed from https://pinside.com/pinball/forum/topic/diverter-needing-warm-up- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
