I am repairing a Williams Taxi.
The last thing I need to fix is the display showing wroung "things".
The top main display is working perfectly.
However the bottom display is acting strangely.
The regular text is showing correctly in this display, but the jackpot value and the status display behind the backglass is also showing in the bottom display.
It does not show as regular numbers (a-b-c-d-e-f-g segments), but as the center segments (h-j-k-m-n-p-r).
The regular text is simply written over the other lit segments.
The status display shows the correct information all the time.
The jackpot value during game over and the bonus value during play.
You can see the segments change in the bottom display as the value changes in the status display.
Things I've done are:
On the cpu board I replaced the segment decoder U44 (74154) due to minor battery damage.
Checked the connections and cleared the (minor) battery damage.
Also replaced the PIA at U41 and U42 trying to see if these were the problem (they weren't the problem).
I've used a display from Jokerz, but it shows the same result.
Here is an image and a video too.
