I have an Earthshaker that I just bought in unknown condition.
Display is showing only 1 or 2 symbols in the middle, it is altering between two symbols (pic 1).
Removed display and cleaned the back pcb and re-soldered some suspected cold joints.
Also tightened the really loose screws that holds the CPU board in place (as if someone had loosened them with purpose).
Re-seated the ribbon cable on the CPU board.
Reconnected display, now the symbols seems to be slightly different than before, not really altering anymore and sometimes the symbol now appears to the left and not in the center (pic 2).
It seems that the symbol is shown in a random place at startup, then it stays there (not moving).
Checked the voltages at the power supply, 100, -100 and 5 VDC are all fine.
What could be wrong? How to troubleshoot from here? I don´t have another system 11b machine to switch displays.
