(Topic ID: 165922)
display not working on Skateball
By Chet
7 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by Chet
#1 7 years ago
My Player 3 display stopped working on my Skateball. It stays black or shows all 1's when game is powered on. Same in display test, stays blank or shows all 1's while all other displays cycle through all the numbers correctly. I disconnected the J1 connector from the player 3 display and changed it with one of the other working displays. The working display works fine in the player three position, but the non-working display does not work in the one I swapped it with which makes me believe the problem is either on the player 3 display board or the display glass. I have good voltages 5 volts and 170 volts on the player 3 display board test points. I have read thru Clays manual as well as Pinwiki's discussion on the Bally SS displays, but nothing there helps me pinpoint my issue or what to check next. Any suggestions on what to check next? This is my first Bally SS so I am on a bit of a learning curve. I was thinking decoder chip, but i hate to just shotgun replace stuff. I did order a new glass from PBR so I might try testing it with the board by touching the pins as Clay suggests..
#2 7 years ago
Is there any reasoning to then you get ones or blank? (for instance, only when the numbers 0, 1, 3, 4, 7, 8, 9 should be on) if so that would point to the drivers for some digits being off. Otherwise, assuming the pins aren't cold soldered, I'd replace the decoder chip.
#3 7 years ago
Morning bump. Any other thoughts from the Bally SS folks?
#4 7 years ago
If the solder points on the J1 header look good, I'd try replacing the decoder. If you had a logic probe you could test inputs/outputs at the 4543 for activity.
#5 7 years ago
Yes, replace the decoder chip on the display's mounted PCB for sure. The glass is very likely ok. If you need a board or a decoder chip, I can probably hook you up with one.
#6 7 years ago
Ok. I socket and put in a new Decoder IC chip and report results. I do have a logic probe. Just not quite sure how to use the LP to test the chip in this instance.
#7 7 years ago
Put a machine pin socket in and installed a new decoder chip. Display works perfect now. Thanks for the help everyone.
Cabinet Parts
Volcano Pinball
$ 40.00
The Flipper Room
$ 44.99
Pinball Shark
$ 119.95
Allteksystems
$ 8.00
Third Coast Pinball
$ 9.95
Playfield - Plastics
The Pinball Scientist
$ 18.00
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/display-not-working-on-skateball and we tried optimising it for printing. Some page elements may have been deliberately hidden.
