(Topic ID: 178164)
Display needed for Alley Cats
By GPS
7 years ago
  • 17 posts
  • 3 Pinsiders participating
  • Latest reply 7 years ago by GPS
    This topic is linked to a classified ad.
    The Ad Listing has been ended, so this topic closed automatically.
    #1 7 years ago
    ARCHIVED
    Archived ad
    Pinside keeps a record of old ads in its Market Archive, for historical purposes and as a price reference. This ad has been ended by its seller and is now archived.
    Parts - wanted
    Added: 2017-01-11 03:11:41 UTC • Ended: January 16th, 2017
    Price
    Hello All
    I am in need of a display for my Alley Cats game. Noticed the other day that one of the segments has failed in one of the displays. Think these are HV units. Don't really want to replace all with Pinscore ones. Any help most appreciated. Thanks guys
    Item photos
    Photos not showing? Make sure your ad blocker plugin is not hiding them.
    Contact
    Note! This is an archived ad. No longer for sale!
    Seller insights
    These are GPS's market stats.
    All ads
    0
    24
    Archived ads
    10
    11
    Success
    10
    14
    Feedback score
    5
    100.0%
    Go to GPS's stats page
    Listing result
    The seller marked this ad as "not sold". The item did not sell through Pinside so there's no listing result.
    Item location
    Mentor, OH, US
    #2 7 years ago
    That is not a problem with the display. Its a board problem.
    #3 7 years ago
    I agree with grumpy. You might be able to just reflow some solder or replace a resistor and be good. Display looks nice.
    #4 7 years ago
    GPS do you have a logic probe? This maybe a resistor network going bad.
    #5 7 years ago
    Sorry for the long delay in getting back. No I do not have a logic probe. Happy to obtain one though. Are you thinking it isnin the board the the ribbon cable from the display plugs into? I recently had the main board serviced and thatvshoikd be ok
    Thank you all
    G
    #6 7 years ago
    Quoted from GPS:
    I think everyone that's wants to do repairs should have one.
    Quoted from GPS:I recently had the main board serviced and thatvshoikd be ok
    Things break...... what can you do. This problem is either CPU, ribbon cable or display driver board. You could move the display to a different position, for example swap player 3 ribbon cable with player 4 ribbon cable. Do the cable swap at the display driver board. If the ribbon cable is bad the problem will not move, but if the problem moves to the other display then its the display board or the CPU board. When you get a logic probe this will only take a few minutes to troubleshoot. I can't find a diagram for this, is this a system 11?
    #7 7 years ago
    Yes grumpy. It is a system 11. Doing the quick cable swap now. Standby
    #8 7 years ago
    Does this have six players? Does player 1 and 2 have alphanumeric displays or are all the display seven segment?
    #9 7 years ago
    When I swap on the display bird the ribbon cables for player 4 and 6 he problem display remains #4. The bird number is D-10749.
    #10 7 years ago
    Here a the scheme of that board
    #11 7 years ago
    Quoted from GPS:
    This sounds like the ribbon cable is bad.
    #12 7 years ago
    If it was a display board issue when I switched the player four and player 6 ribbon connectors at the display board it should have followed the switch and player 6 display should have exhibited the same issue but it did not
    #13 7 years ago
    Ok what I just did was to swap ribbon cables from display 4 and connect it to display 2. The problem dis not follow to display 2. I did this right at the displays. I also found that is I gently tap on the glass display that is having issues I can get those segments to light up. Hmmm. Cold solder joints maybe. Reflow in order??
    #14 7 years ago
    Pushing on the actual display also results in the segments momentarily returning. A reflow is in order I believe
    #15 7 years ago
    Quoted from GPS:
    Yep.
    #16 7 years ago
    It should be pin 20 on the display.
    #17 7 years ago
    Thanks so much grump. Appreciate the assist.
    George
    This page was printed from https://pinside.com/pinball/forum/topic/display-needed-for-alley-cats and we tried optimising it for printing. Some page elements may have been deliberately hidden.
