(Topic ID: 196196)
display just all went out please HELP
By radfordian3505
2 years ago
  • 12 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by wayout440
#1 2 years ago
i just bought this bally harlem globetrotters pinball machine today and all the score displays including the balls have went out and want to know if it would be a fuse problem or not
#2 2 years ago
check the fuse on your solenoid driver board.
#3 2 years ago
thank you so much that was it and my fuse that i replaced it with is bigger in actual size.do you think that will matter
#4 2 years ago
just make sure it's the same value. This is the fuse it should have. http://www.marcospecialties.com/pinball-parts/F8AG-0.187
#5 2 years ago
Always go smaller if you don't have the correct amps until you get the correct one, I am assuming "bigger" meant higher amps.
#6 2 years ago
no actually bigger in actual size
#7 2 years ago
done i just bought them.thank you so much for the help
#8 2 years ago
You need to make sure its value is no more than 3/16th Amp, fast blow. Since it blew once already, putting in a slow blow or one with a rating higher than 3/16A could result in board damage or, at worst, a fire.
#9 2 years ago
and why does the entire game flicker when i hit either flipper button
#10 2 years ago
would battery corrosion cause this
#11 2 years ago
Quoted from radfordian3505:
Because the flipper coils are high voltage. A little dimming is normal. A lot of dimming wouldn’t be normal.
#12 2 years ago
Repin connectors. Replace main filter cap C23 for +5 VDC logic. Review the repair bible, perform reliability upgrades.
http://techniek.flipperwinkel.nl/ballyss/rep/index1.htm
Third Coast Pinball
$ 14.50
PinballElectronics.com
€ 3.95
Multigame
$ 21.00
Trade
