(Topic ID: 241336)
Display Issues and Everything Stopped
By stinkie
5 years ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by cottonm4
#1 5 years ago
I just upgraded to an Alltek LED driver board and swapped out the playfield. Until last night, we have been unable to play a ball with all lights working and most displays working. That didn't last long (around 30 balls). There are a number of issues I could use some wisdom on.
1. Displays. They were not working well prior to playfield swap. Player 1 display would turn on and off, then went off completely. During self-diagnostics, Player 1 would have 1 digit display one number off sometimes, so for example, while the other four displays all showed 111111, player one would show 101111. You could see the zero change between 1 and zero sometimes. Then it might turn off. Usually, if you started a game, it would display. You would see displays flicker when you shook machine.
2. Some kind of short. My kids and I were playing a few balls, then I noticed when I hit a flippers, the lights would dim, so I started hitting them quite a bit, then all control lights stopped along with all other functions. The GI lamps stayed on. Now, when I turn machine on, the GI lights turn on, but it does not 'boot-up'. I am unable to get into self-diagnostic mode. All fuses are fine (1 on pf, 6 on rectifier board, 1 on solenoid driver/voltage reg board).
3. Same Player Shoot Again. This was showing up without even playing. It didn't happen every ball, but quite a few.
4. Left lane too small on new play field - doh! (see image).
5. Posts don't line up for several plastics. (see images) I think I should try to use the plastic as a template for new hole(s).
Thanks in advance!
InkedIMG_2705_LI (resized).jpgInkedIMG_2705_LI (resized).jpgInkedIMG_2706_LI (resized).jpgInkedIMG_2706_LI (resized).jpgInkedIMG_2709_LI (resized).jpgInkedIMG_2709_LI (resized).jpg
#2 5 years ago
Sounds like a connector issue. Reseat J4 on the MPU and on the SDB.
IF the balls are getting stuck in the sides, see if the correct size posts are installed. Eight Ball has two sizes of posts - I don't have my information any more, but I think the slingshot plastics use the taller posts.
Before asking, do a search for Eight Ball posts - maybe someone has already posted which location gets which post.
#3 4 years ago
I not only searched pinside, I googled. Thanks for that. I think the lesson I am learning here, is that you should post a single issue.
#4 4 years ago
Get out the Dremel tool and rotary bit. Check your plastic and see which direction the post is hanging up on. Then take off a small bit of plastic and retry the fit. Keep taking off just a little bit until you have a loose fit.
2,500
Tehachapi, CA
$ 11.00
Third Coast Pinball
$ 29.99
Pinball Shark
$ 12.00
$ 179.00
$ 69.00
Pinball Pimp
$ 69.00
Pinball Pimp
$ 99.00
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/display-issues-and-everything-stopped and we tried optimising it for printing. Some page elements may have been deliberately hidden.
