(Topic ID: 203942)
Display acting up on bride of pinbot
By sbjmg
1 year ago
  • 13 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by sbjmg
#1 1 year ago
The top line is displaying weird hieroglyphics all of a sudden. Tried restarting and unplugging and re plugging the ribbons. See picture thanks
#2 1 year ago
Did you try reseating the ribbon cable at the MPU?
#3 1 year ago
Yes
#4 1 year ago
Can you post a picture of the MPU board?
#5 1 year ago
Thanks, there was acid damage before. When I get home I will try flipping the cables instead of just re seating them. If I knew which resistors would have an effect on this I would shotgun it and replace all. Thanks for you help. I also attached a picture of the display board.
#6 1 year ago
Not sure where to go from here, I am assuming the problem is the MPU board but not sure what to replace. I pulled the board out completely and put it back in to no change. Hoping someone can tell me which components on the board could be the culprit.
#7 1 year ago
That MPU needs a lot of work to get rid of that alkaline damage. Most of that corrosion is going to affect your switch matrix before too long if not taken care of soon.
Have any other MPU boards to put into the game to narrow down the problem? Also need to see the top half of this MPU board.
#8 1 year ago
Thanks, I have attached the full picture. I do have access to another MPU board, but was unsure on how to take out the main CPU (square shaped chip). I have a general IC puller for the roms but not one for the square shaped piece. Was hoping I could just replace a couple resistors and clean up that area as a quick easy fix but not sure if that is the case...
#9 1 year ago
I believe the issue is most likely on your display board not the MPU.
#10 1 year ago
Where would I start there?
#11 1 year ago
OK, i swapped in a semi working MPU board from a Ster Trek Next Gen, and the display works but it says ball missing even though all three ball are in there. Not sure if I need to swap any settings or jumpers to make this thing work properly.
1. I know the issue is with the MPU Board, so what parts need to be swapped (after cleaning the board).
2. If I want to use the spare MPU board what needs to be changed to make it work (ball missing error).
#12 1 year ago
Did you swap the game ROM? That is the only thing that needs to change.
I would get a quote on getting that BOP MPU repaired. It needs a lot repaired and the battery corrosion needs to be neutralized properly.
#13 1 year ago
Just to close the loop, I swapped MPU boards and it worked, still not sure what happened to board but I sent it out.
$ 369.00
2,960 (Firm)
Colorado Springs, CO
$ 40.00
Metal-Mods
