I need a pic of the Safe House switch from underneath the pf showing where/how switch mount is and possibly a pic of the blade on the switch. Don't know if you can post pics here, but you can pm for my email.
The problem was the switch in the Safe House was not registering all the time. I swapped the blade w/a new cherry switch as vendor didn't have complete switch. The blade that was on my switch was mostly straight w/a slight bend upward at end. To make it work I had to mount the switch by the one mounting screw closest to 'hole'...it worked.
Found the correct switch w/blade(number escapes me at the moment but can post back) that is different. Blade bends up then 'loops' down.(best I can describe) When I installed the switch it was closing as it layed against bottom of pf. Tried to bend it w/out success. Length of blade seems to short
Am I missing something or do I possibly have wrong switch? Shouldn't be so but a bit baffled.
Any help greatly appreciated. Thanks in advance.
