(Topic ID: 217947)
Dirty Harry evolving issue now effects play
By topkat
5 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by Scoot
#1 5 years ago
My recently acquired DH has had an issue where in attract mode, or even at times during the game it would sound as though a solenoid or kicker is firing.
Now during play the game seems to think a ball is in play at times, but there isn't one out. IT goes through a cycle where everything kicks and then the ball comes out. IT looks as though when a ball goes into hq, it rolls to the kickout hole and stays there. sometimes 2 balls will be lined up in the trough.The kick out works when its activated, just doesn't seem to sense it right. I am assuming this the same problem that was making the noise on its own before, and has gotten worse.
Is it possible its related to the opto switch for the magnet which is broke, or is this likely a separate issue. Thanks for the help..Trying get this figured on first machines
#2 5 years ago
Sure sounds like some switches/optos are not working. Game relies on these switches to fire coils and keep track of balls. I would go into the switch test and test every switch in the game. The manual will help to locate all switches. Maybe some switches just need adjusting or optos cleaned.
#3 5 years ago
My DH had an issue with the connectors on the 12v board under the middle of the playfield that supplies the optos. I received trifurcon pins and a new connector.housing and have never had the issue again. Check there. Could just be cracked solder on a connector but I question the pins as well. They get cooked and oxidized.
#4 5 years ago
Before you start tearing everything apart, make sure to check that the balls are all moving forward down in the ball trough. Sometimes on mine they get a little sticky and don’t slide all the way forward. The Optos don’t sense them and starts the search for them. This started happening when I added shiny new balls.
#5 5 years ago
Sorry, I should have read your post carefully before I replied. Might be faulty optos or maybe needs a cleaning. Try cleaning the optos before you start replacing them.
$ 22.50
bdash's bits
7,495 (OBO)
Plantsville, CT
4,699
Anderson, SC
$ 9.95
$ 399.95
Pin Stadium Pinball Mods
5,800
Clovis, NM
$ 37.50
$ 5.00
$ 199.95
PinSound
$ 115.00
5,200
Elkhart, IN
KAHR.US Circuits
$ 45.95
$ 95.00
Pinball Mod Co.
This page was printed from https://pinside.com/pinball/forum/topic/dirty-harry-evolving-issue-now-effects-play and we tried optimising it for printing. Some page elements may have been deliberately hidden.
