(Topic ID: 264339)
Diode Reads Bad in Circuit and Good Out
By PinballGurus
#1 4 years ago
Dumb question... I’m having an issue with Checkpoint blowing the F2 fuse on startup. Apparently the issue is related to the pop bumpers... I tested a pop bumper diode in circuit and it read bad, but when I pulled it out of circuit it read good. I checked the coils and they were all good, but the one with the bad diode was only reading 3 ohms instead of 4 ohms. Any ideas what would cause this?
#2 4 years ago
Electrons take the path of least resistance. In the case of your solenoid the electrons pass through the wire rather than the semi-conductor. When you take the diode out of circuit there is no alternate path for the electrons.
#3 4 years ago
If you suspect a problem with a diode, just replace it. It's not unheard of for components to fail under load. Once you have a new diode installed, then see what happens.
#4 4 years ago
Quoted from PinballGurus:
F2 on which board?
3 or 4 ohms is the resistance of the coil winding you are measuring.
The diode can't be tested on the coil.
Coil resistance can vary.
#5 4 years ago
You guys are awesome.
F2 on the power supply board, which is a newer board.
0AE07E5C-66C4-4EDC-92A2-7AC456A646BB (resized).jpeg0AE07E5C-66C4-4EDC-92A2-7AC456A646BB (resized).jpeg
$ 44.99
Pinball Shark
$ 5.00
$ 18.95
$ 54.99
$ 8.00
Tools
Nezzy's Pinball Prints
$ 29.99
$ 27.95
$ 27.95
Professor Pinball
This page was printed from https://pinside.com/pinball/forum/topic/diode-reads-bad-in-circuit-and-good-out and we tried optimising it for printing. Some page elements may have been deliberately hidden.
