I have an Eight Ball Deluxe LE and have a question about the diode's on the flipper coils. The 2 left flippers work fine and when I measure the diode's on these flipper coils (with meter in Diode mode), both read .2 for the left diode and 0 for the right with continuous beeping - the right flipper reads .2 for the left diode and .188 for the right diode - continuous beeping for the left diode and only beeps once on the right diode.
Is this indicating that the right diode on the right flipper coil is bad and if so, what causes these to fail - is there a common issue that would cause this?
(When I measure these diode's in Ohm mode on the meter, I get 3 ohms for the left diode and .2-.5 for the right diode (Left 2 flippers) and on the right flipper, I get 3 ohms on the left diode and 310 on the right diode).
The right flipper does not fire when the switch is pressed - both left flippers work fine. When pressing the right flipper switch, I feel vibration on the flipper bat but it will not work.
TIA
