Quoted from BJM-Maxx:How will you re-attach the lip you removed when cutting out the floor?
I make an "L" shaped channel out of 3/4" plywood. Once I Bondo the outside, it will look original. Might have time to do that today.
Quoted from Brazy:Nice thread J... looking good....$80 bucks and we'll take that eyesore of a slot out of your basement...hehehe
$100 and I'll bring it to Bob's next Saturday.
Quoted from Jjsmooth:$100 and I'll bring it to Bob's next Saturday.
Bob’s is gonna get wild. Don’t leave right after league. Just saying.
Like this
1562873431074800725047 (resized).jpgGlad to help.
Decal time. Cut to edge of print and lay on cabinet side. Keep consistent overhang (mine was 3/4"), check for design center, and tape in place with painters tape (only). Once decal isin right spot, I cut 3 notches to cabinet edge, and secure half the decal.
Quoted from Jjsmooth:Attach a straight edge to end of decal. This keeps the corners from flopping over and ruining your day.[quoted image]
loving the straight edge tip!
Quoted from Jjsmooth:Restoration decals from Treasure Cove are a nice touch.[quoted image]
Where did you find those on their website? That’s a great touch!!
Quoted from djblouw:Where did you find those on their website? That’s a great touch!!
Contact pinsider Athens95. He does them.
Quoted from mof:What's the install like for those?
Easy. 2 sided tape.
Getting the old ones off, a bit tougher. Heat gun and pry them off.
Looks great so far. While your at it, you may want to consider installing a beefier leg bracket.
https://www.pinballlife.com/williamsbally-new-style-leg-bracket.html
Can I ask what "Bondo" do you use? I know there are many different types.
My issue(s) are some Bondo is so tough, it sets up quickly and many times it's so much harder than the wood, then it's difficult to get Bondo & wood smooth (inconstant materials).
Any help / advise would be greatly appreciated!
Kerry
It takes time to get a feel for whatever product you are using.
I have found that if you put less hardener, it is easier to work with. And it clogs up sandpaper way less.
Use a random orbit sander, start 80 grit, 120, primer
This is what I use now, because I can sand in 15 minutes. Love that.
Quoted from Jjsmooth:This is what I use now, because I can sand in 15 minutes. Love that.
Thanks for sharing... Maybe I should experiment with using less hardener too.
Quoted from Jjsmooth:It takes time to get a feel for whatever product you are using.
This is what I use now, because I can sand in 15 minutes. Love that.[quoted image]
That's ok filler, but I always use Z-Grip,
It's alot easier to work with
Quoted from ArcadiusMaximus:Looks great so far. While your at it, you may want to consider installing a beefier leg bracket.
I was going to say the same. After restoring a few pins, these are a must.
Quoted from Flynnyfalcon:I was going to say the same. After restoring a few pins, these are a must.
Not really. The length of thread is the same, and that is what is important. I'm not looking for structural help on the cabinet, I have that taken care of.
This page was printed from https://pinside.com/pinball/forum/topic/diner-resto/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
